Reference
Old Oct 10, 2016 | 02:38 PM
turley68delta88's Avatar
Reference
My 455 has 440,000 miles on it, would a rebuild even be worth it and what would be the price range for that?
Old Oct 10, 2016 | 02:44 PM
Welcome to the site, your question is basically the same as me asking you how much it would cost for you to build me a house with no other details. Your rebuild cost will be based on what the engine needs as far as machine work and parts. 440k miles is quite the accomplishment with no past rebuilds.
Old Oct 10, 2016 | 03:00 PM
Thanks I'm glad to have found this website and thanks for the reply, I've had this car for only a couple months and had no problems with it till recently I even drove it 90 miles to the beach and back and it ran perfect, it has an exhaust leak and needs a new air filter and maybe a new carburetor, but most things in rebuild would be minor this car has 3 unoriginal parts and the only thing redone is the roof in the interior. I would like to keep this car as long as possible even if it sat until I had the money to fix it, sorry for the mouthful
Old Oct 10, 2016 | 03:06 PM
What are the 3 unoriginal parts?
3,500 would be about my limit I know since there have been no rebuilds and few replacements it might need more work than I am aware of but all of it would be worth it to me if I got it to run smoothe with only regular maintenance and the occasional minor or even somewhat major fix
Old Oct 10, 2016 | 03:55 PM
Alternator, radiator, carburetor, and actually the brakes were recently replaced and the ignition switch
Old Oct 10, 2016 | 04:03 PM
So your engine has never been opened up in 440k miles? I truly find that hard to believe. I'd budget $4-5k for a simple rebuild at a machine shop to include new fluids, belts, engine mounts, and all new tuneup parts if you remove and install it yourself.
Old Oct 10, 2016 | 04:08 PM
m371961's Avatar
My curiosity is up. If you have only had it a few months, how do you know it has 440,000 miles?
You never know how much a rebuild costs until the engine is apart. All internal moving parts must be measured.
Have you ran any diagnostic engine tests?
Old Oct 10, 2016 | 07:37 PM
That's all the records I have of it, but you're pros back right and thanks I'll have to think about it
Old Oct 10, 2016 | 07:50 PM
It was my uncles previously and he told me that it is the original mileage so as far as I know it is, and I'm going to do that this Thursday
Old Oct 10, 2016 | 07:54 PM
440,000 miles is highly unlikely, but I suppose not impossible.
Regardless, if there's nothing wrong with it, I'd tune it up and run it - you don't rebuild an engine without a reason.
Welcome to ClassicOlds.
Old Oct 10, 2016 | 08:10 PM
ELY442's Avatar
You know that saying, "If its not broken, dont fix it".
Old Oct 10, 2016 | 08:11 PM
steverw's Avatar
Maybe its just 44,000 miles? The last number to the right, usually white is 10'ths. That would make more sence. Anythings possible, just sayin.
Good luck
redoldsman
Apr 8, 2012 02:51 PM
Akoostics
Tech Editor's Desk
May 25, 2011 06:38 PM
MDchanic
Sep 29, 2010 02:05 PM
oldsmansugar
Dec 23, 2009 05:59 AM
