Rear axle
Old Aug 14, 2009 | 11:43 AM
n8ivbeast's Avatar
Rear axle
Hey there guys how you all doing. I have a question to ask all of you. I have a '64 Olds Jetstar 88 and something went out in my rear axle i do believe. The driveline still spins but it won't go into any of the gears. so its always in neutral basically. So if it is my rear axle what Cars could i use to swap it out or what would you recomend doing in this situation?
Old Aug 14, 2009 | 05:11 PM
citcapp's Avatar
Could be a couple of things.
1. You broke an axle
2. You broke the spider gears
You need to remove the axles and check them out if the axles are not broken the you need to remove the differential housing (leave the axles out to do this. it contains the carrier, spider gears & ring and pinion. You have to disconnect the driveline to do this as this unit comes out from the front of the housing. Once you do this take a picture of what you see. These can be replaced as a unit for a wrecking yard and can be found with a some searching. Maybe someone who reads this thread has one available. You need a manual to repair if you have to take it apart.
Old Aug 14, 2009 | 07:08 PM
Unfortunately, the 1964 J88 rear axle is unique to the 1964 J88. The good news is that the internal parts are common to the A-body, so if it is a spider gear or something internal you should be able to get those. The axle shafts are unique, but if you do need an axle, Moser and others will custom make shafts for a reasonable price.
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
dan1s
Mar 16, 2008 11:13 AM
<powers455>
Sep 13, 2007 09:11 PM
