Possible Oldsmobile Engine Ideas For A Hot Rod Project.
OK, here is the deal. I am new to working on cars. I grew up around classics and I have always wanted one and finally managed to purchase and 1956 Oldsmobile Super 88. I want to make it into a rod.
I want to keep my car Oldsmobile specific. With that in mind I need an ideas on possible Oldsmobile engines that would be great for a Hot Rod project. Details and specifics would be great. Again, keep in mind I am new to all of this and am looking for information from people willing to be helpful.
I like your enthusiasm and suggest you channel it into planning the whole project before you buy anything or grab a wrench. Starting here asking about ideas was a smart thing on your part. Some of that you can get here but some of it you gotta get around to car shows, cruise-ins etc. to really lay your eyes on it. Seeing it is vastly different than hearing or reading about it.
A concept for your hot rod Olds will eventually come to you that will probably be a cross between what you dream of having and what financial reality may limit you to. Then you start figuring out all of the modifications you need to make and how they will go together. What parts you will need and how much all that costs plus how much time it will take. Be realistic about how much you can do yourself. But don't be afraid to push your limits and develop new skills during your build.
Hot rodding's bugaboo is unintended consequences, i.e. change one thing and it affects things you hadn't even thought about. Put all the stuff you wanna do down on paper and then talk to people who have built similar cars to test your ideas. You will avoid a lot of troubles by doing that.
There is a lot more to a rod than just a bigger, badder engine. The rest of the drive train has to be able to stand up to it. The radiator has to be able to cool it and the suspension has to keep it safely between the lines on the road.
I wish you the best of luck and a heck of a lot of enjoyment on your project.
This article's a few years old, but a good one if you decide to "rod" with the first generation Olds engines. (In order to view it, i had to disable the Firefox Adblock).
http://www.streetrodderweb.com/tech/...s/viewall.html
I have kept the original mill in my 57 and rebuilt it warmed over. I would suggest a 3 duece setup for your 56. I converted mine to a 4 speed but in retrospect a 55 hydro might be a great choice. The early hydros have one less turbine and get better mileage and performance. This combo would have been a late 50s hot rod and held its own with most chevy 265s and 283s.
Welcome aboard
The slant pan hydro is a good choice for your transmission . They are Hell for strong and have a killer first gear coming off the line. If you wanted to go crazy with the horse power thing a 394 will fit nicely, (with mods)and can be dressed up to look just like a 324, pretty easy for a super sleeper. By the way all this will cost quite a few bucks but would be high in the cool factor....Lost in the fifties but not looking to find my way back.....Tedd
Welcome aboard
Click on the ABP stopsign on the bottom left of the web browser...then go up to "Disable on this page" AFTER you click the link. Don't do it while on CO or it'll open up the can-o-worms.
To the OP...if you wanna rod it, you have to have twin turbo's...don't ask why, just do it
It'll be cool!
It'll be cool!
There many different ways to mount a later model olds engine in there also depending on your fabrication and welding skills. The suggestion above about figuring what you want vs how deep your pockets are first is an excellent choice.
The things one does as a teenager.
.. Tedd
Olds engines...
While there may be a cool factor associated with the older Rockets, it would be hard to beat the simplicity of a later model 455 or 403 or 350 in your Olds. I have a 455 in my '51 Ch*vy pickup and am about to replace my 350 in my '39 Olds with a 403. My '39 frame is similar to your frame and the new mounts were pretty easy to fab...
To me, there is a extended level of comfort walking into a parts store in Resume Speed, Nebraska and buying a part for my later model Olds engine!
IMHO.....
IMHO.....
One really cool factor on the early Olds engines was the valve covers on the 49-50 303's that had the valve covers with the spark plug wire looms in them. I understand they are prone to leak which is probably why they quit using them.
Your iron manifold will work very well with a 4 barrel. I used to use pre quadrijet Rochesters and they work well . Your stock carb may be a Carter and it will work fine also. You can put a bigger motor in your 56 but it WAS the bigger motor in 1956 and whatever you put in someone will have one bigger, The old Rockets are really no harder to rebuild than a small block Chevy except for the non adjustable rockers. I use Smith,s adjustable pushrods in my 57.
As for a rod motor:
http://www.ebay.com/itm/1959-1964-39...8e79f1&vxp=mtr
I called them today. They said he has a guy that has built some one off ones but I am looking at $1800.00 range. No plans to mass produce one as of now.
IMHO.....
IMHO.....
...Lost in the fifties ...Tedd
Somewhere in my junk I have a diagram on how to adapt the 49-50 valve covers to a 394 by making a two bolt apparatus to hold the valve covers on. The 49-50 valve cover hides all the holes of the later 394 styled valve covers. Quite simple really, Nothing was said about problems with leakage as I remember but there could be. I always thought it would probably fool most all but the real hard core Olds guys..Tedd
Hay guys this post is five years old but still has some good info for others who maybe in the market for a hotrod conversion, I doubt the original poster still needs the help after fife years though some builds go a decade or more..... Tedd
Tedd,thanks for noticing the age of this post,but can someone tell me why this happens.
I don't usually look to see when it was originally posted,just assume it is current.
If I put up a fence post at home ,I usually assume that it wil be rotten or eat up by termites
by the time it is 5years old. Larry
X2 what Rocketowner said.
Some of these posts are like zombies and come up out of the grave by means not known to mortal men.
Inquiring minds want to know how this happens.
My theory: there is a jokester among us who goes to the graveyard of forgotten posts and revives them to see who is paying attention.
Jerry
Jerry
widowmaker1201
Dec 2, 2012 01:52 PM
