Pistons
Old Apr 15, 2015 | 02:58 PM
jamades's Avatar
Pistons
Good evening. My name is Jeff and I have a 64 Cutty, holiday coupe. 330 cid factory a/c factor buckets etc. I am in the process of putting a budget together to rebuild the 330 engine. The problem I am having is I am not having any luck finding pistons. I realize I may not need them but I want to make sure they are available. Any help would be greatly appreciated.
Jeff
Old Apr 15, 2015 | 07:46 PM
jamades's Avatar
Originally Posted by jamades
Good evening. My name is Jeff and I have a 64 Cutty, holiday coupe. 330 cid factory a/c factor buckets etc. the cutty sat in a barn for 12 years. I bought it almost 3 years ago and have been tinkering with it ever sense. I am in the process of putting a budget together to rebuild the 330 engine. The problem I am having is I am not having any luck finding pistons. I realize I may not need them but I want to make sure they are available. Any help would be greatly appreciated.
Jeff
Old Apr 15, 2015 | 07:50 PM
oldstata's Avatar
Justin
Not sure on your question but I was wondering if your ac is complete could you take a few pics and post them for me ?
To this thread https://classicoldsmobile.com/forums/small-blocks/91486-1964-only-330-only-ac-brackets.html
Welcome ! To CO post some pics of your car and maybe, start a thread telling alittle about yourself and your car/ plans
Old Apr 15, 2015 | 08:00 PM
steverw's Avatar
Try EGGE pistons, not sure if they make them for the 330 but they might. Others here will know if there are other options.
Old Apr 15, 2015 | 08:01 PM
jamades's Avatar
As far as i know it is original a/c. Most of vacuum lines are gone because once i touched them they fell apart. What kind of pics are u looking for? Lines, condenser, drier, I will have to figure out how to post pics on here.
Jeff
Old Apr 15, 2015 | 09:52 PM
Egge Machine is one source for cast pistons; you could get forged pistons custom made by just about any of the major piston manufacturers; or you could overbore the block to use standard 350 pistons. The last option may require sonic checking the block to ensure there is enough material for the overbore, but I have read that many folks have done this with success.
Old Apr 16, 2015 | 05:43 AM
Egge and Kanter both sell stock replacement cast pistons. If you want forged, you'll need to look for custom aftermarket.
Old Apr 16, 2015 | 08:07 AM
jamades's Avatar
Thnak You. I will take a look at those companies.
Jeff
Old Apr 16, 2015 | 08:12 AM
Oldsmaniac's Avatar
True, but if you order them from Kanter they will come in an EGGE box and will cost more....
Old Apr 16, 2015 | 09:24 AM
That sounds just like what an unpopular west coast operation does with commonly available aftermarket parts.
Old Apr 16, 2015 | 10:26 AM
GEARMAN69's Avatar
These folks have them
http://www.supercarsunlimited.com/Pistons-i105.aspx
Old Apr 16, 2015 | 11:15 AM
Oldsmaniac's Avatar
Originally Posted by GEARMAN69
I would not be surprised if these were also EGGE pistons...
Old Apr 16, 2015 | 11:36 AM
GEARMAN69's Avatar
Seeing a set of cast over $400 seem like for just bit more you could get a flat top forged custom 330 piston
72 Supreme
May 20, 2008 04:06 PM
Olds71suprema
May 10, 2008 09:44 AM
77omega
May 9, 2008 07:25 PM
Big J
Apr 21, 2007 08:31 PM
VanZant
Aug 7, 2004 03:44 PM
