oldstoro66
oldstoro66
Joined 7-9 mos.ago, just getting back. I have a 66 Toronado,mysecond. Purchased it in 2003,and Dad & I have been tinkering,replacing parts,etc... and still enjoy the ride!! Currently I am replacing the A/C pump and most components,and also the Chain & gears. The car had spent some time in Calif. so it is a bit sluggish(emissions)I'm using a 3 keyed gear and plan to go w/the +4 advance on the sprocket. Any suggestions pro or con? Thanks for reading!
Thanks Joe! My toro has an air pump,EGR set-up and HAD a vacuum retarder inline. Am going to end the egr system at the steel pipe that the head tubes lead into.Just (2) pipes to crimp instead of 8 Has heads that are light green to say the least. EGR tubes,big B on each head.
I strongly suggest that rather than crimping the tubes (which are a somewhat rare part these days), remove the tubes at the cylinder head using the flare nuts and install steel flare nut plugs. These are not pipe thread holes, they are inverted flares like brake line fittings. Here's one source of the plugs, though any well-stocked auto parts store should have them.
http://www.valleyhydraulic.com/store...-Plug-c117.htm
I will do that. I can take suggestions very well. Thank you, Joe. And to think all these years i've called them an air pump. Well "technically" it is. Only it's an A.I.R. pump......Is it a good thing to leave the A.I.R. in place and still do away with the timing retarder?
