Olds custom cruiser 1988 no coolant to heater core
Old Aug 23, 2013 | 09:22 AM
Armando S Nortez's Avatar
Angry Olds custom cruiser 1988 no coolant to heater core
This problem started not to long after my wife was using the car and the coolant light came on she let some stupid sears people put dex cool in the engine. this car had never had dex cool used in it just standard coolant.
suddenly after the car has no heat ive check the heater core water flows easily in either direct i removed the vacuum controlled heater valve top piece with a pipe cutting tool so just the stud was left and placed the heater hose directly on it. I've changed the thermostat and refilled the system to capacity.
The outlet that is the hose that sends coolant to the heater core in take does not have any coolant coming out no more then a small trickle then nothing.I know this because i was able to remove the hose while running the engine hot and no big steam cloud what could be causing this.
307 Y ENGINE WITH COMP CONTROLLED Q JET ROCHESTER
Old Aug 23, 2013 | 10:14 AM
pogo69's Avatar
morgan
not sure if this applies to your set up but this is what i found when i had no flow to the core of my truck
Old Aug 23, 2013 | 10:40 AM
was that after a coolant change or anything that seems like it could be a winner
i let you know when the car comes back its still running like a champ im just trying to figure this out before it gets cold out
Old Aug 23, 2013 | 11:23 AM
pogo69's Avatar
morgan
no nothing special i attribute that to 100,000 mile dexcool...i dont like it... i have had trouble with it...and i dont use it anymore
Old Aug 23, 2013 | 04:37 PM
Redog's Avatar
Stop driving it and get all that Dex Cool crap flashed out.
You cannot mix Dex Cool with the green stuff, it turns into a gel like stuff and, well yeah look at the pic above.
Complain to Sears!!! Don't know the extend of the damage, but it cannot be good
Armando S Nortez
Nov 15, 2013 08:43 PM
angkadkins
Jul 23, 2013 08:24 PM
Death
Mar 7, 2012 03:03 PM
Death
Jan 25, 2012 07:33 AM
PalmSpringsOlds
Vista Cruiser & Wagons
26
Aug 14, 2010 12:01 PM
