oil pan torque
Old Jul 13, 2009 | 03:00 PM
oldsvair's Avatar
oil pan torque
what is the correct oil/trans pan bolt torque settings (1969 455)
Old Jul 13, 2009 | 04:38 PM
citcapp's Avatar
12-15 lbs
Old Jul 14, 2009 | 03:12 AM
Rdrokit's Avatar
citcapp is correct but some things to think about. If it is a new gasket go ahead and torque them bolts but if the car has been sitting for some time do not torque those bolts. After sitting for a long time a gasket could get brittle and it you torque it down there is a chance that the gasket will be damaged. Drive the car for a few hundred miles and let the gasket absorb some of the oil and soften up. Then go ahead and torque them down.
Old Jul 14, 2009 | 06:43 AM
wolfman98's Avatar
Captain of my ship
trans pan
I just put a filter kit on my 69-98 455 cid and I believe the service manual said that the torque was 11 lbs. It may have been 12 but I know it was not too much. That would be if you are putting in a new gasket. The kit I got had a rubber gasket and I added a film of Permatex on both sides for a little extra comfort on my side.
Old Jul 14, 2009 | 07:54 AM
And just to clarify, the units of torque are FT-LBS in this case (as opposed to IN-LBS).
Redog
Oct 20, 2015 03:29 PM
atkinsom
May 25, 2015 09:25 PM
AzChevs
Oct 8, 2014 10:13 AM
defiant1
Aug 12, 2014 04:43 PM
