newbie in vancouver
Old Mar 31, 2014 | 03:56 PM
1951super88's Avatar
newbie in vancouver
Hello Olds Fans.
I have a 1951 super 88 with a rocket 303 and i have a few concerns.
i have blow by coming back thru the oil fill tube and its bringing oil with it that gets blown all over by the fan.I am getting some blow by thru the vent tube but shouldnt all come out the vent tube? do these vent tubes become blocked and can they be cleaned out or replaced?Does any one sell these anymore . Thanks for reading this.
Old Mar 31, 2014 | 06:20 PM
Tedd Thompson's Avatar
Welcome aboard. Good question, I've also seen this but I have never seen a vent tube(down draft) clogged to the point it would hold back pressure. Usually when there is that much blowby it's time for a freshen up ring and valve job.
It you don't have power brakes(and I don't think you do in a 51) you might try installing a PVC valve on the down draft opening at the back of the block and this will sometimes suck the oil vapors through the carb and take at least 1/2 or more of the smoke out of the picture. If you have power brakes this adaption bleeds of to much vacuum and makes your booster inoperative... Just a few thoughts ....Lost in the fifties...Tedd
Old Mar 31, 2014 | 06:50 PM
Rocketowner's Avatar
Welcome to C.O. You might remove the lower breather tube and try washing it out in a parts washing machine.I have seen them get partially stopped up and force it out where you put the oil in,but like Tedd said ,that's usually a sign of rings that have lost their tension,and time for a rebuild.If it don't have air conditioner, they are easy to rebuild.We had a mechanic that could start on one at 7 AM.,replace the rings ,reface the valves,and drive it to go get his wife when she got off at 4PM. I've seen him do this more than once. Larry
Old Mar 31, 2014 | 10:15 PM
Welcome, blowby is a sign of worn rings as the other said. Short of a rebuild there really is no cure. Post some pictures of your car when you get a chance.
Old Apr 1, 2014 | 07:04 PM
OLD SKL 69's Avatar
GM Enthusiast
x2
Old Apr 2, 2014 | 02:02 PM
Thank You All for the info. when it stops raining i will post some pics
604Cutlass
May 21, 2015 03:23 AM
Big Dawg
May 13, 2015 02:23 PM
1972w30convert
Feb 2, 2014 10:03 AM
Miniucco
Feb 28, 2010 05:30 PM
agtw31
Apr 26, 2009 12:48 PM
