newbie needs help
Old Jan 21, 2016 | 07:54 AM
mario455's Avatar
newbie needs help
hello guys,new to this, hope you can help me,tuning problem with a 403 cannot get it to completely stop pigning detonating:1978 403 block bored .030,probe pistons,cam extreme energy 268h-10:268-280,224-230 at .050,485-490,heads 350 big valves ported cfm 217-167,compression 10.2,performer rpm,quadrajet stage 2,proform HEI,compression test 150 to 160 ,running 91oct pump gas, tryed a lot of things ,timing at 25 total with slow curve,
Old Jan 24, 2016 | 10:57 AM
tomyturbos's Avatar
What is your static timing?
Did you set the timing with the vacuum advance disconnected and plugged?
Have you checked for vacuum leaks?
Old Jan 25, 2016 | 05:19 PM
mario455's Avatar
no vacuum and the timing is initial 14
2000 rpm=23
2500 rpm=26
total timing 26
its the max that it can take
Old Jan 25, 2016 | 05:48 PM
mario455's Avatar
no vacuum leak the car runs pretty good till 2500 rpm but doesen't pull any more after that with out pingning !
billmerbach
May 16, 2014 11:39 AM
sparkysgarage
Jun 11, 2009 07:04 AM
64starfireme
Apr 11, 2009 06:40 AM
72greensupreme
Site Help
Mar 24, 2009 05:59 AM
DinkyDow
Sep 1, 2006 05:02 AM
