Newbie has a 442 shifter?
I have a shifter that has 442 on it. Figured a 442 forum is the place to find out if its an OEM or a Hurst aftermarket, or some other aftermarket. So I guess I'll post in the tech section with some pictures.
Fred.
Fred.
It's a factory Hurst shifters. The aftermarket shifters only have the "H" on the stick, and the stick bolts on. The factory Hurst shifters have the "442" numerals and a snap-in stick (to speed up assembly line installation).
Good point. I ***-U-MEd that the O.P. was talking about a Hurst shifter, not a Muncie shifter. To be completely correct, prior to 1966, shifters used a flange-mount handle that was held on by two bolts. This is not the same as the "lap joint" bolt-on handles used on the aftermarket Hurst shifters, but it is an important distinction for correctness.
marxjunk
Jun 12, 2014 12:34 PM
oldriverking
Jan 4, 2011 01:30 PM
oldsdroptop
Jun 2, 2009 07:03 PM
