Newbie with 72" 442 W-29 4-speed car
Old Jul 9, 2017 | 09:15 AM
  #41
SteveRob442's Avatar
Originally Posted by Allan R
Steve,
The crumple fenders were introduced in 1971, but stock of 1970 fenders were installed on early production 1971 cars. By the time 1972 rolled around the crumple fenders were the only ones being produced and installed for 1972 models.
Your rear end is likely a 2.73:1, which was the standard gear ratio for 1972 Cutlass S, as was the 10 bolt corporate rear.
Nice find on the Fisher broadcast card. IIRC the W29 should be in box 12. That is the official authentication you need for your documentation. The body number on the broadcast card should match the body number on your cowl tag. From the rest of your post, A51 is strato bucket seats, and it looks like your car body was sequenced for build at Lansing Fisher Body Works on March 6 of 72. It would take 2-3 days to build the body and install cabin details and glass before the car was sent to Lansing final assembly. That's why the cowl tag info doesn't match the VIN. Final assembly sequence is the last 6 digits of your VIN.
Your car was built a month before mine at the same plants.
Overheating on a 350 seems a little unusual, even with the 195 t stat. I'd want to take the 350 apart and see if it has suffered and head gasket damage or warped the heads. What kind of documentation do you have to support the overheating, or was it just word of mouth?
Cool! The W-29 marking is in fact in box 12. The card is so delicate. I had the writing spaced like the card when i typed it but it did not stay that way when it posted. I took the radiator to a radiator shop. It is blocked up and corroded and has leaked right at the tanks. The guy said it isn't worth repairing so i order a new aluminum with a two-fan system. I will find a new original reproduction later. I have a compression gauge set that can also do a leak down test. I plan to do the leak down test in the next few days or so while waiting on parts to come it. I am currently cleaning the underneath for painting, taking the rear-end out of the car and changing the upper and lower arms for the rear end with new units that have the poly bushings. I'm saving all original parts. I also have all the seats and carpet out. I will vacuum the floor, wire brush where needed and coat the floor, then lay the sound deadening material then lay the carpet back into place. Any idea what coating to use for the floor? Thanks guys.
Old Jul 9, 2017 | 09:17 AM
  #42
I'm lazy. I'd run a leakdown test first, before any teardown. There are a lot of possible reasons for overheating.
definitely will do that! I have that test kit from my racing days. thanks
Old Jul 9, 2017 | 03:25 PM
  #43
Floor coating? I think it depends on your plans for the car. If it's not going to be a daily driver, and you're not driving it in the winter? I'd just go with splatter paint and call it good. You're planning to cover it with sound deadener anyway, which will seal the floor pans from any moisture penetration from above. When I had the carpet and jute out of my 72, I noticed it wasn't painted on the floor pans at all.
Scan and save the documentation. You likely could also get the broadcast card cold laminated to further preserve it.
Dave Siltman
Sep 28, 2012 12:02 PM
Dave Siltman
Jun 8, 2012 02:49 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
NewOldsGuy
Jan 1, 2010 05:33 PM
