Newbie
Old Sep 12, 2020 | 11:46 AM
DirtyDawg's Avatar
Newbie
Thanks for letting me join, just bought a 76 Omega and looking to fix it up.
Old Sep 12, 2020 | 12:09 PM
Welcome to the site, congrats. Post some pictures when you get a chance.
Old Sep 12, 2020 | 03:42 PM
69CSHC's Avatar
Nice, welcome aboard ! I am a fan of Omegas.
Whats your powertrain ? I understand your car came with a inline 6 up to a 350 V8. What are your goals ?
Old Sep 12, 2020 | 04:18 PM
rocketraider's Avatar
Oldsdruid
Welcome. The key to dealing with an Omega is that it shares a lot with same-year Novas. Meaning there are parts available.
Old Sep 12, 2020 | 04:54 PM
DirtyDawg's Avatar
260, TH350
Going to swap motor in the near future, not sure if I'm going 350 chev or bigger olds motor, will have to change trans if I go chev, not sure wich way right now.
Old Sep 12, 2020 | 05:14 PM
Tj Pal's Avatar
Welcome! I hope you are able to keep it all Oldsmobile.
Old Sep 12, 2020 | 05:27 PM
Oldsdruid
There are enough Olds 350s around that there is no good reason to turn it into a Nova. Just take advantage of the repro stuff that's made for the X-body car.
Old Sep 12, 2020 | 07:15 PM
69CSHC's Avatar
Originally Posted by DirtyDawg
260, TH350
Dead nuts reliable combination. The engine doesn't make enough power to even-remotely hurt itself and the trans is designed to handle twice the power. Driven with care and respect should last forever...
As an Olds guy I too would prefer that you went with another Olds engine and a bigger small block is a perfect match to your transmission. Any Olds 350 will make considerably more power than a 260. Its an automatic 50% increase in power minimum. Not enough... ? work that 350 to the tune of 300 HP or so and you are 3 times the HP your car was born with. With your small light weight body should make for a 13 second car with the right rear and gearing.
Alex Melucci
Jun 24, 2019 03:39 PM
m371961
Feb 3, 2013 11:13 AM
Al Sanchez
Apr 19, 2012 02:23 PM
Dr-O
Feb 23, 2011 12:52 PM
