New to Olds, Old to cars...
Old Jan 10, 2012 | 04:16 AM
GLH's Avatar
GLH
I'm new to Oldsmobiles, but I have been playing with cars for 20 years.
I'm looking at a 1976 442. It has a 455 and a four speed trans.
How do I go about determining if it's an original 455 four speed car?
I'm looking for info on VIN decoding, production data, etc
Old Jan 10, 2012 | 05:44 AM
2blu442's Avatar
Welcome to the site! Sounds like a cool car! I'm not familiar enough with that vintage to answer your question. If you don't get the answer here I'd encourage you to check out this other Olds site:
http://www.73-77olds.com/index.php
John
Old Jan 10, 2012 | 05:49 AM
cutlassgal's Avatar
Cutlass Lover
Welcome to our site!
Old Jan 10, 2012 | 07:32 AM
jaunty75's Avatar
What is the VIN?
Old Jan 10, 2012 | 08:11 AM
wmachine's Avatar
Trying to remember member
That's an easy one. It is not an original 4-speed. Factory 4-speeds were not available after '73.
Old Jan 10, 2012 | 08:42 AM
DENT's Avatar
Welcome. There was a 5 speed manual option in 76.
Old Jan 10, 2012 | 08:47 AM
wmachine's Avatar
Right, but that was not a high performance deal, it was only available with the 260 and would not bolt up to *or* hold up with anything bigger.
Old Jan 10, 2012 | 09:17 AM
Starting with the 1972 model year, the VIN will tell you what engine was factory installed. An original 455 car would have had either an "S" or a "T" as the fifth character of the VIN.
http://service.gm.com/dealerworld/vi.../vincard76.pdf
Old Jan 10, 2012 | 11:13 AM
GLH's Avatar
GLH
Engine digit is an F. That would make the original engine the 260. I'll have to look and see what the numbers on the engine are. I'ts definately a 455 and may be worth buying for the drivetrain.
Thanks for the help.
Old Jan 10, 2012 | 12:32 PM
I'll bet it was a 260/5 spd car to start with (relatively rare, actually), which would have made it pretty easy to swap the 455/4 spd combo.
Old Jan 10, 2012 | 02:19 PM
m455sx's Avatar
Olds Nut
yes a very rare car, post some pix when you can.
Old Jan 10, 2012 | 03:28 PM
Does that mean that you could get a 4 speed in 73? I've read on other forums that you could, and still others (and members here) that say the 73 Cutlass / HO was only available with a 455/400.
So am I describing 2 different issues?
1. HO production
2. 73 455/4speed option
I would like to know because I don't have a CSM or AM for 73 and there's nothing on WAC about this either.
Old Jan 10, 2012 | 06:31 PM
wmachine's Avatar
1. HO production
Okay, but I know you mean "nothing on WAC yet", because it is coming!
Yes, 2 different issues. In '73, the M20 4-speed was available on any 2-door Cutlass model. But its was not available with the H/O in '73.
Old Jan 10, 2012 | 08:12 PM
That would explain a LOT! I sure hope I didn't upset any of the HO guys. I really am looking forward to when those new CSMs and AMs hit WAC.
Old Jan 17, 2012 | 11:27 PM
spiderjason's Avatar
Welcome to the forum!!!!!
Old Feb 7, 2012 | 05:02 PM
442much's Avatar
In 1976, as stated, they never made a 455 4 spd in an Olds, although you could get one in a Trans Am. There should be a "T" in the VIN to indicate a 455 engine, but that would have been mated with a THM 400 tranny and you had to have power brakes too.
Your VIN decodes like this: 3 (Olds) / G ( Cutlass S) / 37 (2 door HT Coupe) / T = 455 / 6 = 1976 / M = Lansing / 123456 Plant seq. No.
Good luck and welcome.
1969w3155
Jan 27, 2013 03:23 PM
Rowdies
Feb 10, 2012 07:57 PM
jaunty75
Aug 20, 2010 03:24 PM
GoodOldsGuyDougie
Jul 26, 2010 05:03 PM
67 Cutlass
Oct 13, 2009 06:56 PM
