New & Needy
Old Mar 29, 2012 | 11:52 AM
Bill Moon's Avatar
New & Needy
I have a 63 Oldsmobile Dynamic 88 Holliday and have been trying to locate a vacumn controled heater control valve, but most places don't have the year listed. It is located on the right rear of a 394 cu with A/C, I thought there would be a suitable valve used on later models but need some help.
Bill
Old Mar 29, 2012 | 12:13 PM
Bluevista's Avatar
Registered
Welcome.
If it's the right thing USA Parts Supply shows a "Hot Water Valve" in their catalog for all '61-'63 88 and 98.
A later one may work if the pipe thread is the same or could be adapted , if it's what I'm thinking it is.
http://www.usapartssupply.com/index.php
Old Mar 31, 2012 | 08:54 AM
Bill Moon's Avatar
Heater Control Valve
Thanks BlueVista. I ordered some parts from USA Parts Supply and ask about the valve but was told they did not stock it and could not get it. I appreciate your effort.
Bill Moon
Old Mar 31, 2012 | 09:27 AM
Rickman48's Avatar
Try Fusick's or The Parts Place - it's also called the heater control valve, and am surprised the local auto parts stores can't get them!
Old Mar 31, 2012 | 09:47 AM
rocketraider's Avatar
Oldsdruid
I went thru this with a 64 over 20 years ago, and finally found one in an old parts store downtown that closed up a few months after I got the valve. The 64 was a one-year-only app, natcherly.
Parts book says 1959-63 except F85, group 9.795, p/n 575097, hot water valve assembly on engine.
If you cannot find that specific application, a little ingenuity can pay off. Use a pipe nipple where it screws into the intake, then find a readily available inline valve like Chevys and some Pontiacs used. Make sure it operates same as the original (vacuum open or vacuum close) and this should get you working until you can find the correct part.
You'll also find that short of a show where you might run into someone who knows about such things, most people will never be the wiser about the valve being in the heater hose instead of screwed into the intake.
Old Apr 18, 2012 | 07:46 AM
Bill Moon's Avatar
Thanks everyone for the help, especially rocketraider. The OEM P/N was very helpful. I tried about 23, maybe more parts sites and two said they had one, however only one actually did.
Northwestern Auto Supply in Grand Rapids, MI, 616-241-5611 had a NOS for $60. Same Manufacture as OEM.
Thank Again
orange442
Jul 9, 2015 04:32 PM
BIGJERR
Jun 1, 2010 08:05 AM
StickW31
Feb 25, 2010 01:14 PM
offer
Jul 29, 2008 06:57 AM
many8
May 18, 2008 06:26 PM
