New guy with a 1987 Cutlass Build
Old Dec 25, 2016 | 07:13 PM
spencer83's Avatar
Hi guys I'm from the northern part of Illinois by Waukegan and I'm building my first car. It's a 1987 Cutlass Supreme. Motor is going to be from a 350 out of a 67. I just purchased a crank out of a 330. I was planning on stoking it. 3.5". Trans is a 200r4 and it has the regular 7.5 rear end. I'm looking to reach somewhere in the neighborhood of 450hp. I need options. Carb, cam, intake, headers, pistons, and machine work. Should I keep my heads or get new ones? The rear end 12 bolt chevelle...3:73 (what I was thinking about getting) I'm new to this but I'm willing to learn and take advice. I just want it done right, I'm ready to start building! Thanks guys!
Old Dec 26, 2016 | 04:29 AM
Kennybill's Avatar
Are you sure it came out of a 1967? 1968 was the first year for the 350. You may already have a 330 crankshaft in that engine, if it is a 1967 engine. The 350 Nodular crankshaft is a strong piece. You don't need a forged 330 crankshaft till your making serious power. Jmo. Good luck.
Old Dec 26, 2016 | 04:49 AM
Welcome to the site, we like pics. X2 on the 350 starting in 68, 67 was a 330 in its an Olds engine.
Old Dec 26, 2016 | 05:04 AM
spencer83's Avatar
Thanks guys. This was the engine I wanted to purchase this week
https://chicago.craigslist.org/nch/pts/5899644061.html
I have a 77-80 block in there now but I heard it's weak because it's a windowed main.
Old Dec 26, 2016 | 05:06 AM
spencer83's Avatar
My cutlass
Old Dec 26, 2016 | 05:08 AM
spencer83's Avatar
Thank you
Old Dec 26, 2016 | 06:15 AM
Welcome. The Craigslist motor is a 350. It just isn't from a 67. The seller is incorrect. The second character of the VIN derivative stamp will tell you the model year of the block.
Old Dec 26, 2016 | 07:52 AM
spencer83's Avatar
Thanks, I'll go check it out Thursday.
Old Dec 26, 2016 | 08:01 AM
76olds's Avatar
Hookers under Hood
That's a nice 87', I owned an 86 same interior with T-roofs, I miss that car even thou it only had a chebby 305 back in the day.
T-roofs leaked down the a-pillars but only when it rained!!
Good luck on your new found 350, these guys will nail down exactly what you have to work with. I'm sure it will work out for you.
Thanks for posting the pics brings back great memories of the late 80's long gone by.
Cheers
Eric
Old Dec 26, 2016 | 08:37 AM
CRUZN 66's Avatar
Olds Fever
The seller may not be incorrect... The seller states "Oldsmobile 350 engine, not 100% sure but I think it was made in 1967"... 350 engines were manufactured in 1967 for the 68 model year release... Just saying... Casting number should clarify the actual displacement... Seller may be looking at the casting date...
Old Dec 26, 2016 | 09:24 AM
I think you are giving the seller WAAAY too much credit. A seller who is informed enough to read both the casting date and the VIN derivative to determine it was a late 1967 casting would have stated as much and would also not have used "not 100% sure". It is FAR more likely that the seller is mistaken. The simplest explanation is usually the correct one. I'll bet it isn't even from the 1968 model year.,
Old Dec 26, 2016 | 09:35 AM
spencer83's Avatar
Cheers
Eric
That's awesome! Im glad that I found it in pretty good condition. I'm sure it will work out. It's a lot to take in but I'm learning. I've been trolling for about a month or so. It's amazing to see how much you guys know. I'm excited. Thank you
Old Dec 26, 2016 | 01:35 PM
Pfiffle's Avatar
Keep us posted on your progress. I've owned a few G Body's and they are excellent platforms for a build. I had a beautiful Buick Regal that got T Boned and a couple of Cutlass'. As a matter of fact, I have a doner car (1970 4dr 98) that has a high compression 455 waiting for a home in one down the road.
Tom
Old Dec 26, 2016 | 02:07 PM
That 87 looks nice. I'll just suggest that before putting any money into building it, check the rear frame rails behind the axle for rust. This is a know weak spot on these cars, and rust holes there are common. There are repro rear frame rail sections available.
Old Dec 26, 2016 | 03:20 PM
1969CutlassSBlue's Avatar
Hi , welcome here
Old Dec 26, 2016 | 05:17 PM
CRUZN 66's Avatar
Olds Fever
As Joe said, the rear frame rails can be an issue... Two main areas for corrosion are the body mount areas between the trunk floor and the frame as well as the rear bumper absorber mounting area... I have also had frames with cracks on the side of the rails in the axle arch areas...
Old Dec 26, 2016 | 06:17 PM
Human's Avatar
Forward into the Past
That's a nice, clean Cutlass. The last year for that body style. I really like that two-tone. We don't see too many two-toned cars from that era here in the Southeast. For whatever reason, padded landau roofs were more popular down here.
Old Dec 26, 2016 | 06:32 PM
sammy's Avatar
Sammy70 455 Supreme
Welcome! I put a 350 olds in my 1985 442 ....with headers, you willl have to change the tranny mount. The mount in a 1970 Cutlass convertible will fit. It allows for the dual pipes to pass...my experience anyway👍
Old Dec 26, 2016 | 06:45 PM
spencer83's Avatar
I have duals. I forgot to mention that. Straight back no convertor, 40s flowmaster. So I will have to change the tranny mount for headers? I need some good options for my headers. Thanks
Old Dec 26, 2016 | 06:49 PM
spencer83's Avatar
Thanks! 1988 was the last year for these. I really like the two-tone that I have. I'm going to keep it the colors the same. My friend has a salon with the top and sunroof. It's really nice.
Old Dec 26, 2016 | 06:52 PM
spencer83's Avatar
Originally Posted by 1969CutlassSBlue
Hi , welcome here
Thanks I'm really glad to be here
Old Dec 26, 2016 | 06:57 PM
spencer83's Avatar
Everything looked pretty good. A little surface rust but I checked the whole car. It was a great find. No rust by the tops, doors, trunks, or floors. The carpet is even fresh.
Old Dec 26, 2016 | 06:58 PM
spencer83's Avatar
Thank you
Old Dec 27, 2016 | 05:01 AM
76olds's Avatar
Hookers under Hood
Sounds like you knew what you were looking for. I agree the rear frames aren't the best for holding up.
You may want to drill a couple 3/8- 1/2 holes near the back of the frame for drain holes, GM's designers/engineers forgot to add them to the design i think.
Sounds like you have a nice solid car to work with, congrats on your purchase.
Eric
Old Dec 27, 2016 | 05:10 AM
spencer83's Avatar
Eric
That's a good idea, thanks.
Old Dec 28, 2016 | 08:04 AM
btw's Avatar
btw
Smokin' BBQ Member
Congrats on your purchase. There is a good stand of Oldsmobile owners downstate (Peoria/Galesburg) you'll want to get with and a few troll on here. Post some more pictures when you get them and at the first sign of spring - shed the t-tops and get that Olds on the road!
Old Dec 28, 2016 | 08:39 AM
spencer83's Avatar
I appreciate it. I'm proud of my cutlass, I think I made a good buy. I can't wait until the weather breaks, and yes the tops are coming off!!!
Old Dec 28, 2016 | 09:19 AM
spencer83's Avatar
I'm so glad to be on this site, gbodyforum, and rop. I'm learning so much and I couldn't be more thankful. I went to a shop a few months when I bought my car and talked to them about doing some upgrades to my engine and beefing it up. These creeps talked so much trash about my Olds 350. They told me that it would just be easier to find a Chevy 350 and redo that. My heart was broken. Seriously. Then I did some research, watched a ton of videos and found out so many great things about my motor. I will take my time and get my cutlass right. Who cares if it cost a little more, and harder to find parts. This makes the build a little more special if you ask me. That's why I won't do a ls swap, sbc, 455, 403, etc. 350 it is!
Old Dec 28, 2016 | 09:56 AM
Human's Avatar
That's just their laziness talking and an excellent indicator that you're better off not doing business with them. It might seem somewhat expedient to drop in a Chevy 350 but is it necessarily the right thing to do? After all, it's a Cutlass, not a Chevelle, and it's supposed to have a Rocket under the hood, not just on the grille.
Old Dec 28, 2016 | 10:36 AM
spencer83's Avatar
You're right
Old Dec 28, 2016 | 02:08 PM
  #31
ROCKETMAN269V's Avatar
Email sent.
Old Dec 28, 2016 | 03:49 PM
  #32
coppercutlass's Avatar
Chevy budget Olds powered
Welcome and nice build. Lots of die hard olds guys in that area. Me included. I used to work in Lake bluff. If you ever need a hand let me know. Don 80 rocket works at TnT engines in gurnee. You should hook up with him . Great guy knows his stuff.
Old Dec 28, 2016 | 05:09 PM
  #33
spencer83's Avatar
I went to tnt! He wasn't there. I talked to the owner. The son Tom I think. They told me the olds speacialist would love me! I need to talk to him asap
Old Dec 28, 2016 | 05:19 PM
  #34
Then member Dave 67 cutlass freak does amazing port work. He did my cylinder heads up for another 355 olds I am currently building. He's just over the border in wisc. Good luck with the build.
Old Dec 28, 2016 | 05:34 PM
  #35
spencer83's Avatar
Thank you. I'll keep you posted and everyone else. I really appreciate the help and suggestions.
Old Dec 29, 2016 | 07:38 AM
  #36
Turns out if you zoom in on the first photo in the CL ad, you can see that this "1967" Olds 350 has no. 8 heads.
As usual, the seller is mis-informed.
Phoenixsheperd
Aug 8, 2014 05:16 PM
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
major tom
Apr 18, 2012 01:01 PM
69 442 protour
Dec 9, 2006 09:25 PM
