new to this
Old Feb 13, 2016 | 02:32 PM
86cutlass salon's Avatar
new to this
hello my name is Bryan I have a 86 cutlass salon I'm trying to buy new rims from my car and I'm trying to figure out specs for the rims if any one can help me out on this that would be very helpful 'm trying to put a 15x7 on I have 14" rims on it now
Old Feb 13, 2016 | 02:52 PM
Welcome to the site, the 15x7's will be fine. The wider you go the more careful you need to be to prevent tire rubbing issues.
Old Feb 13, 2016 | 02:53 PM
wheel specs
trying to buy new rims for my 86 cutlass salon but i'm trying to figure out wheel specs but trying to use a 15x7 but I have a 14" rim on it now?
Old Feb 13, 2016 | 02:56 PM
As I said in your newbie post the 15x7 will work fine. You need to be careful as you go to the wider selections to prevent issues.
would a 15 in. x 7.0 in., 5 x 4.75 in. Bolt Circle, 3.76 in. Backspace work for it?
Old Feb 13, 2016 | 03:15 PM
Yes the 15x4.75 is correct, there is not much back space deviation in 7" wide wheels. It starts to be problematic when you get to the 8"+ widths.
Old Feb 13, 2016 | 03:16 PM
CRUZN 66's Avatar
Olds Fever
If you want to avoid any clearance issues, keep the back spacing at 4.0/4.25... This is standard for 15x7 SSIII wheels... OEM=4.0... Reproduction=4.25...
Last edited by CRUZN 66; Feb 17, 2016 at 03:34 PM. Reason: Correct OEM wheel Dimension
Old Feb 13, 2016 | 03:31 PM
ok guys thank you for your help
Old Feb 14, 2016 | 08:18 AM
Originally Posted by CRUZN 66
If you want to avoid any clearance issues, keep the back spacing at 4.25/4.5... This is standard for 15x7 SSIII wheels... OEM=4.5... Reproduction=4.25...
You sure about that? Offset should be close to zero on the original wheels. That means backspace on the stock 7" wide wheels would be between 3.75 and 4.0, allowing 1/4" to 1/2" for the inboard wheel lip. Larger backspace will push the tires closer to the pinchweld on the wheel opening, potentially causing rubbing.
Old Feb 14, 2016 | 09:40 AM
CRUZN 66's Avatar
Olds Fever
Now you have me second guessing myself... IIRC those numbers came from when I measured an 84 Hurst SSIII and a Reproduction SSIII... Measurement was taken from the rear face down to the seating surface... I'll have to remeasure when I get a chance... Too damn cold out to do it right now
Old Feb 17, 2016 | 03:39 PM
CRUZN 66's Avatar
Olds Fever
Thanks Joe, I rechecked my wheels... I had the reproduction number correct... However, the OEM wheel is 4.0 as you stated... Just another senior moment on my part... I'll have to start writing info down as I accumulate it and not rely on my memory as much...
Old Feb 17, 2016 | 08:13 PM
76olds's Avatar
Hookers under Hood
Bryan, What type of rims are you planning on putting on your 86 ? I had an 86 Cutlass Supreme going back many years and had cragar SS rims all around , 15x8 225-60-15 and 14x7 on the front running 215 70 14 . I forget the offset but the rear were deep dish with no rubbing the front were regular no offset. I have many pictures of the car but didn't have a computer back then to load them up haha.
Post some pics of your car when you get a chance, we all love pics.
Eric
Sickle
Aug 31, 2013 08:28 AM
ah64pilot
Sep 19, 2012 10:55 AM
ah64pilot
Aug 17, 2012 02:36 PM
skinny
Apr 23, 2007 02:46 PM
redrumloa
Mar 10, 2007 06:45 PM
