Need ac information
Old Apr 6, 2014 | 06:00 PM
72allblackcoupe's Avatar
Need ac information
72 cutlass it has all the parts. I just bought a compressor. A parts guy told me I need a poa expansion valve to convert from 12 to 134a. .. need info on the best way to get some cold air. And where to purchase whatever parts I need
Old Apr 6, 2014 | 06:33 PM
This has been addressed here, and even more on V8Buick.com and AutoACForum.com - You would be wise to do some searching.
What you need is either
a.) to recharge with R12, as the system was designed, or
b.) to replace the receiver/dryer with an R134 compatible unit, replace the condenser with a crossflow type, instead of the original serpentine type, possibly replace the hoses (opinions vary, and you may do just fine with the old ones), flush the entire system to clear out the old oil, readjust your POA valve to work with R134, and refill with R134 at 80% of the amount specified for R12.
Easy.
Old Apr 7, 2014 | 07:52 AM
hookem horns's Avatar
Does the existing sytem hold pressure and fully funstional other than the compressor not working? If you are lucky and this is true, I would consider finding some R12 as Eric mentioned.
If the system is in parts and/or has multiple leaks, think about dumping it and starting over with a Vintage Air (or other) aftermarket system. Not cheap but getting an old system restored and converted to R134 can be a slippery slope.
restoman
Oct 7, 2009 01:34 PM
Autoelegancia
Aug 5, 2009 04:56 AM
dlv4540
May 6, 2009 05:43 PM
diamondave
Aug 29, 2008 01:29 PM
<joyce>
Jun 11, 2004 12:16 AM
