My 1970 cutlass supreme holiday coupe
Working on getting all the pieces together now. Engine and transmission done. Dynamat and re wiring In Progress.
the pro touring kit was from classic performance products
cpp kit
the only issues incurred was the bold holes for my lower rear shocks the differential holes had to be drilled out a bit. also the front shocks were a pain to mount on the front lower control arms with the clips provided. but with a little elbow grease and some grinding of the clips got it done. I would suggest before installing the lower front control arms to weld nuts for the shocks instead of the nut clips provided.
I had a 700R built by performance automatic. with a LIFETIME warrany!
http://www.performanceautomatic.com/...nsmission.html
the holiday coupe model has no post between the windows and I believe the holiday coupe models have extra chrome.
The 700R only requires an adapter plate to work with olds blocks.
