Lowering or not. 1966 Cutlass coupe.
Hello
New member from sweden here. I have a 1966 Cutlass coupe with a 455 in it that needs new springs and shocks. The car is to low in the front, I guess they have cutted the front springs. The rear is way to high and the springs is all worn out. I found some pictures of a cutlass like mine with original springs and shocks and liked it. But I also found 1" lowering springs and shocks for sale and now I need some help. Is there someone here witha a car like this and 1" lowering springs on it? It would be nice to see some pictures. If I order the lowering springs what wheel size could I use without having the top of the wheels hidden by the fender if you all know what I mean. Best regards
Nice looking car. Are you running with original setup? I think I will have the car little bit higher in rear than front. But as low as it is now I got problem on bad roads and long headers. If I buy orignal dimensions of springs and shocks will I get that look? Found some pictures of a car where the guy had lowered the front 1" and as I understood left the rear original? And also som post of guys mounting hd springs in the rear. Confusing all this..
nitrojunkie1029
Suspension & Handling
15
Dec 16, 2014 02:21 PM
