Intro
Old June 28th, 2012 | 06:27 AM
64jetstar88's Avatar
Intro
My wife and I purchased a 1964 Jetstar 88 in the spring of 2011. We love the old gal but it needs a few little bits of help.
I'm having a little trouble removing the door handle and window cranks in order to try to either straighten or replace the window track on the drivers side- I don't see the usual "pin" to release the handles?
The turn signal lever has also "loosed" itself and will no longer engage the turn signals? Any suggestion there?
Thanks for letting me into the group and for any assistance that you can offer-
Steve
Sioux Falls, SD
Old June 28th, 2012 | 06:47 AM
Welcome aboard
I'm not sure if the 64 is the same as the 69 but I beleive it is. There is no pin in the door handles and window cranks, There a "c" shaped clip spring. Any auto store will have the very inexpensive tool for removing them. While you're there, buy some extra clips. They have a tendancy to go "boing " into no where land.
Old June 28th, 2012 | 06:50 AM
The clip is what I meant- sorry- I offered a pretty lame description. I have removed these on other cars and they have always been pretty visible once the door panel is loosened - I just don't see one on or near the base of the handle anywhere,
thank you for the reply
Old June 28th, 2012 | 06:59 AM
They're kinda up in the concave part of the handle. The tool has an offset to compensate. Some people have had luck using a rag to slide up in the area and catch the ends of the clips. IMHO the tool is os cheep it's worth it.
Old June 28th, 2012 | 07:44 AM
citcapp's Avatar
Welcome to CO
Sounds like nice car. Pictures please. The tool Jamsbo described is the easiest way to remove the handle
Old June 28th, 2012 | 07:50 AM
pic- best available right now
I tried to attach a pic- hope it works
This is our first "trek" into the land of older cars and it's been fun. We are planning to use this one as a stepping stone to the next one
Old June 28th, 2012 | 07:54 AM
Welcome to the world of old cars!
Old June 28th, 2012 | 08:04 AM
Oldsmaniac's Avatar
You will need to pull the steering wheel to tighten turn signal arm. Pullers are not expensive for this job as well.
Old June 28th, 2012 | 08:13 AM
Tedd Thompson's Avatar
Welcome aboard, that puller that Oldsmanic spoke of often can be loaned free from Auto Zone and like places......Tedd
BradS
September 7th, 2012 09:51 AM
gunmetal71
June 24th, 2009 05:20 PM
etohboy
May 30th, 2009 02:37 PM
wilfredacree
February 18th, 2009 06:30 PM
car_designer
February 12th, 2009 11:17 AM
Quick Reply: Intro
