Hinges
Old Apr 10, 2015 | 10:15 AM
crowbarr1's Avatar
Hinges
I am new to the forum so please be easy on me. I may be needing door hinges for my 69 Delta 88 convertible and am having no luck locating them. Will any other "B" body fit? Thanks.
Old Apr 10, 2015 | 10:24 AM
Other B-body hinges of the same year range should work, but what's wrong with yours? Typically it's pretty easy (and MUCH less expensive) to replace the bushings and pins. If the bushings are so far worn that the pins have started to egg-out the holes in the hinge brackets themselves, then you'll need replacement, but otherwise you can usually just get away with a bushing and pin kit.
Old Apr 10, 2015 | 12:46 PM
crowbarr1's Avatar
Hinges
Joe,Thanks for the info. I hate to say it but I don't know what happened. Long story short, the car got caught in the middle of a divorce between my daughter and her ex-husband. They owned a auto repair shop and the car was stored there. When I got it back there was alot wrong and no one knew anything. I was told to be prepared in case it does need hinges by two body shops so I figured I better start. I do have the pins and bushings. Thanks again.
shaks 442 clone
Aug 9, 2009 10:12 AM
Jolly Green
Aug 2, 2008 12:51 PM
Jolly Green
Aug 7, 2007 10:40 PM
chuffman
Jun 6, 2007 09:23 PM
