Hello Forum!
Hello Forum!
I'm a Hillbilly from Lynnwood, WA (a little North of Seattle). I just bought a 1956 Oldsmobile 88, (standard version), two door post.
It has the 324 Cubic Inch V8 with a 4-barrel, good tires with mags, automatic transmission. The body is straight with a little minor rust that needs R&R. Relatively fresh dual exhaust.
The factory master cylinder leaks so finding a suitable replacement is my first order of business, (any help you fellers know about would be appreciated). She is missing the door panels; (I hope I can find 2 interior door panels). She needs a driver's side floor pan, (I maybe able to weld the factory one as it isn't too bad). She needs paint.
I was originally gonna fix her and sell her, butt: I really like her so I'm prolly gonna keep her. I haven't named her yet, (I usually name my cars and trucks).
I have a 2008 Crown Victoria Police Interceptor, (Vicky), and a 1987 F150 4x4 (Black Betty). I had a 1956 pristine Chev that was stolen back in the day, (the '56), this is me first Oldsmobubble. My friend's Dad had a super cool 1952 88 and a 1953 98 that I remember well.
The "oldmercsrule" name I've used for many years, (on boating and political forums). I own a private island, and run a bunch of inline6 Mercury outboards, (tower of power). Very fast, very inexpensive to run and maintain.
I hope this info helps you fellers ta know me a wee bit.
Glad to be here,
Respectfully,
murky
Glad to be here,
Respectfully,
murky
Congrats on your purchase. Since it is a regular 88, it will have the hydra-matic instead of the Jetaway which is a stronger transmission. You will notice it has no P position on the shift indicator which means there is no position for park. You park it in reverse and a parking pawl engages when you turn the key off. Also, the 4-barrel has been added since the 88 originally came with a 2-barrel. You should probably consider having your existing master cylinder rebuilt. Karps Power Brake Service (Home - KARPS POWER BRAKE SERVICE & CYLINDER SLEEVING (karpspb.com) does a great job and has been in business a long time. We really need to see those pictures.
I need to black out the plates to send the front and back view. I left the plate of the car hauler in one, (I'm not very smart).
I need to ponder antitheft on this girl, I had a secret switch to ground the points on the 1956 Chev which didn't work, (obviously).
The previous owner said it runs on 87 octane regular with a lead additive, (maybe because the 4 barrel was added after the fact)??????
I will run pure dinosaur fuel, (no alcohol), is he correct about regular grade fuel????
I always ran mid-grade in the 54 I had. It should not have but it wanted to ping a little bit on the 87 octane. I never used any lead additive. This old gal looks to be in pretty good shape.
The next two pics show the only minor rust on the right side front of the hood. Doors close like a vault, everything is in line so likely never stacked up.
Chrome is also decent.
I had never seen them on the domed Oldsmobile tail lights before. It was believed to make a car visible in fog at night. Read the link below.
https://mechanics.stackexchange.com/...rom-the-30s-to
If that's the one in your avatar she's a looker.
I wish mine was that color, when I repaint I'm stickin' with the stock colors, (my Lady friend put down her size 6 shoe).
Yours looks to be the Super 88 Holiday coupe. SWEEEEEEEEEEEEEEEEEET!!!!!
Hello again
It's been almost a year since I posted. I've been working on the old girl, (decided to call her "Lucile"). Replaced the fuel tank, (and associated sending unit, in tank filter et al). Replace the master, shoes and wheel cylinders, brake hard and rubber lines, two front drums, and new shoes. New core in the radiator, new battery, and lots of smaller things.
I'm gonna fire her up (prolly next week give or take). The only thing I've done wrong so far is using the smaller rear wheel hydraulic cylinders on the front, (not power), brakes, before I found a source for the correct larger cylinders. I will be careful when I take her around the block.
I'm gonna post a few questions a bit later in the classic section that have come up.
This forum is fantastic, as even though I haven't posted I've lurked and learned.
I will post in black and white per yer request.
Respectfully,
Murky
Welcome aboard, I'm also a mid-fifties Old's guy but a 55. If I read correctly you have standard non-power brakes. You could throw a rebuild kit for cheap and save your self some money plus a bunch of time as Karps Power Brakes is one of the best but very slow and busy. You might be able to run a hone and re kit it and be done in a day. I also run 87 octane in my 55 with no ping but you do have a little higher compression in a 56 than in a 55, you might try a tank full and see if your car likes it... Lost in the fifties.. Tedd
You are one of the great posters on this forum who has taught me a lot, (as I've lurked and learned). Thanks again. BTW your 55' convertible is gorgeous, (as is the model in the pics)!!
I've already gone through the standard brakes and I will stick with what I've done. If the undersized front wheel cylinders cause me an issue, I will buy the larger cylinders and change them out.
I have 5 gallons of fresh pure dinosaur 87, (no alcohol), that I will try with some additive to compensate for the lack of lead. The guy I bought the car from claimed he ran on 87. I plan to flush the first few cups of gas, (in the brand new fuel tank I installed), through the fuel pump and hard lines, and then install a vintage Delco fuel filter I found on Ebay in the glass separation bowl.
I had hoped to fire her up and get her on the road this week, but: I've had to order some more electrical ignition parts as I've cleaned up and gone through all the old electrical contacts n' such. Hopefully: next week.
This base 2 door sedan Oldsmobile does have some unusual features. It has the 4 barrel Rochester 4jet carb, and the Jetaway transmission with "park". Hard to know if a previous owner swapped these, my guess is they are factory, (someone checked the upgrade boxes in 1956).
Thanks again for your very helpful posting here on this forum.
Respectfully,
Murky, (Jim).
Mr Jim, You will find things like that especially if the car was ordered and not just bought off the show room floor. I have seen post cars with stainless rocker molding 4bbl carbs and other generally higher model upgrades, one doesn't know if these are a factory upgrade or just something that has been added in the last 60+ years unless you have a build sheet or window sticker. Enjoy your ride, looks like you are going all in. What are your ideas on paint or are you going rustic?
I really don't like green, especially the shade of green on this car. The only exception for me, (and my Lady: "the real boss"), is dark "British racing green". Once I get her on the road, (and sort out any additional mechanical issues), I will carpet the cabin, (it has a green rubber mat that has fallen apart), replace the seat belts, replace the two door panels, replace the kick panels and package tray. The front bench seat needs attention, (likely new dark green vinyl on the bench part of the seat is the solution).
The hood will be brown primer once the rust patches are welded, and then two tone dark British racing green and either ivory or very light green hood and above body chrome. Similar to this 4 door example \/\/\/ except I'd pain the top dark green.
