Heating up, what the hell:)!
Old Jul 14, 2016 | 06:12 PM
TonyHurst's Avatar
Okay, I have a 1970 cutlass s with a 350 rocket and AC. Im getting ready to lay behind the car on a hill and let it finish me off, lol! The overheat idiot light kept coming on, so I did the following:
-put in a three core aluminum radiator
-put in a new thermostat(twice, 180 degree vice the 195).
-new water pump
New lower hose(nice and stiff)
-installed a temp gauge (twice)
What I got from both gauges is a crazy fluctuation from 190 or so to 260 in less than one second, and then back down to the 200 or so range. When I stop and shoot the thermostat housing with a temperature gun it says it is at about 200-210. What the hell is causing this?
Old Jul 14, 2016 | 06:16 PM
You have an air pocket in the cooling system. You need to work it out, I usually stuff a water hose into the radiator filler neck with a slow flow of water with the engine running.
Old Jul 14, 2016 | 06:18 PM
Yep, air in the system. I once had a slow radiator leak and I knew when the coolant level got too low as the gauge would spike as you described.
Old Jul 14, 2016 | 07:26 PM
TonyHurst's Avatar
Old Jul 14, 2016 | 07:27 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Be sure the temp sending unit is actually submersed in water at all times like on top of the manifold. If it is not you will get strange readings.
Old Jul 15, 2016 | 01:17 PM
TonyHurst's Avatar
Thanks for ya'lls help!!!
Thanks fellas, Im gonna check that out today!!
gearheads78
Oct 31, 2010 12:31 PM
jeffreyalman
May 29, 2010 06:37 AM
Uncle Hulka
Jan 31, 2010 09:21 AM
Allan R
Nov 15, 2009 07:53 AM
relic
Feb 23, 2008 04:43 AM
