Got my car back Whaaaa hoooooo
Old Jan 18, 2016 | 01:53 PM
angelo68442convertible's Avatar
Check this out boys and girls. I will start the re assembly process now.
Old Jan 18, 2016 | 01:57 PM
Awesome
Old Jan 18, 2016 | 02:42 PM
76olds's Avatar
Hookers under Hood
Looking good , I'm 20 min from you how did the body work?
Old Jan 18, 2016 | 03:09 PM
Hwy 9 auto body painted it. It was mostly done. They just cleaned and painted. Came out half descent. Chris is a great guy.
Old Jan 18, 2016 | 04:21 PM
allyolds68's Avatar
Very nice. That was quick
Old Jan 19, 2016 | 08:34 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Is that code D sapphire blue poly or code F teal frost poly? Looks nice. Are you applying the W36 stripe?
Last edited by droldsmorland; Jan 19, 2016 at 01:29 PM. Reason: Mike caught my error
Old Jan 19, 2016 | 08:44 AM
16Victor's Avatar
Schwing! Nice...
Old Jan 19, 2016 | 09:22 AM
Thanks. F code Teal. No stripe originally so no stripe now. Numbers are not in the right place and don't like the look if not positioned properly
Old Jan 19, 2016 | 09:51 AM
allyolds68's Avatar
Teal Frost actually
It could have had a Black, White, or Red Y70 pinstripe......
I vote for Red,
Old Jan 19, 2016 | 11:50 AM
Can you believe that it only says Y70 stripe decal side. No color. Black might be cool. I'm worried about not getting someone to do it straight. It would have to be painted on if I did it. I have heard it would have been white on my car.
Old Jan 19, 2016 | 01:42 PM
Thanks for correcting me on the color Mike! How was the holidays for you and fam???
Angelo... thanks for not applying a W36 where it dont belong. Whats in store for the wheels? SS1s with Red lines would pop (we can help you spend your money lol). But SS11s cool too. Im runnin non orig bolt on center SS111s to match the red body. Like that look. But now I need new rubber and 225/14s are too thin so gotta step up to 235, 245 or 255/15s so Im steppin up to new SS1s with Red lines before this years cruse season starts.
Turnpike 442 vert. Wonder how many of the 3476 total were TPCs. Yours is an automatic right?
Old Jan 19, 2016 | 01:59 PM
Already got the SS1's was looking for red lines but the build sheet says White Walls. Not a big fan. I will look for a set of red line 14in tires. For now I will probably put the tires on it over on to the SS1's Will Try to sell those SSII's and have the money for the tires. I am frugal not cheap. I just don't like having a lot of extra stuff anymore. Getting old.
Old Jan 19, 2016 | 06:52 PM
Anyone know of a kit that contains all clips I need to install the side mouldings.quarter panel right up to the tip of the fender? Just found that drivers side has 69 moulding and passengers side has 68 moulding. Got to get a drivers 68 2 piece moulding as well. But would love to know if there is a kit with all clips please. Or if you know the numbers of what I need would be great too.
Old Jan 19, 2016 | 06:54 PM
Sorry Drolds yes my TPC is automatic. Will have the 425 in it 2 barrel like the 400 that was originally in it.
Old Jan 20, 2016 | 02:43 AM
allyolds68's Avatar
Fusick sells all the clips. They are the correct finish as the originals and priced accordingly ($$$$$). They also know exactly how many clips you need and what type. There are aftermarket suppliers like Auveco automotive fasteners that sell aftermarket aftermarket that will work but not be "correct" but you have to know what you're asking for when you place an order.
Does your door have studs or holes in it for the trim?
I don't have the part numbers for the fender trim spring clips but I'm sure others can tell you. They are very common. The door has two special clips at each end that I bought at Fusick. They are spring clips but they have a screw instead of a stud. If the door has studs it uses a plastic clip. The rear 1/4 uses spring clips at each end and a different plastic clip for the slotted holes.
I was lazy and bought all the fasteners at Fusick.
Old Jan 20, 2016 | 06:09 AM
Doors have studs yes requires plastic clips. I will call Fusick and see. Thanks.
Old Jan 20, 2016 | 07:38 AM
allyolds68's Avatar
Fusick will tell you exactly how many clips you need and what type
Old Jan 20, 2016 | 02:58 PM
Yellowstatue's Avatar
Someone in Bolton has fender clips for sale on Kijiji. If you want to see what a white stripe looks like on a blue car, come over to my place for a look at Muskrats convert...ten mins. to me...9 oh five seven 7 5 six five 37.
hamco53
Jan 1, 2015 07:22 PM
Tedd Thompson
Oct 7, 2014 07:59 AM
Tedd Thompson
Dec 24, 2013 08:34 AM
65az
Oct 31, 2009 09:47 AM
65az
Oct 27, 2009 08:50 AM
