GM Dealer Tester#BT-6508
Old Oct 28, 2010 | 05:01 PM
edsel's Avatar
I have a1968 442...gas gauge reads full (with key on) all the time.
Factory service manual says to hook up Tester BT-6508 to test gauge!
Where could I rent/buy or get an electrical diagram to build this tester.
Thank you !
edsel
Old Oct 28, 2010 | 05:08 PM
compedgemarine's Avatar
generally when they read full the sender has failed or there is a break in the electrical circuit, i.e. the wire going to the sender broke or the ground wire from the sender is not grounding.
Old Oct 28, 2010 | 05:22 PM
edsel's Avatar
Thanks for the reply. Will check thoes things out! edsel (because that was about
the only user name not in use yet)
Old Oct 28, 2010 | 05:25 PM
in the trunk where the wires go through to the outside there should be a plug for the sender. if you unhook it there and ground it the gauge should come all the way down, if it does the issue is probably the sender or the ground wire.
Old Oct 28, 2010 | 06:11 PM
edsel's Avatar
I grounded the wire in the trunk...the gauge dropped to empty. when I released the ground it went back to full! Will check the wire to the sending unit & the sending unit tomorrow. Thank You for your help ...EDSEL
Old Oct 28, 2010 | 07:32 PM
Oldsguy's Avatar
Past Administrator
Welcome to CO, I hope you can get the problem corrected, good luck.
Hairy Olds
Feb 10, 2020 06:34 PM
L77F85
Dec 25, 2013 10:12 AM
pcard
May 15, 2013 10:10 AM
coltsneckbob
Oct 8, 2010 05:23 PM
kbass72
Apr 18, 2008 11:29 AM
