Floor pans...HELPPPP
Im looking for floor pans for my 1982 Olds Custom Cruiser..i cant find any repair panels for that Olds year...anyone know of similar makes or models that might work?
idiot comments
My 82 is actually very clean 1 owner,85,000 original miles//im replacing the floor pan because the driver side was lowered onto a jack stand,which poked a hole in the floor...the passenger side is fine..your ignorant comment is the reason i dont join forums..if you cant help shut the **** up...sorry to the rest of the forum
That doesn't sound like it needs replaced ... any competent bodyman should be able to hammer it back into shape and weld the hole up in under an hour. It's a whole lot less work to fix that than cut out the pan and replace it ... should you find one at all. It's not like it's a fender that has to be mirror perfect.
As you pointed out, it sounds like a localized repair to an otherwise nice car, so you now have some options for finding what you need. The rest of us also need to chill a little here.
I think j's comment was based on the fact he assumed it was a rust bucket. I would not go through the trouble of replacing the floor pan if it's not rusty. I would fix or salvage what's there. Sheet metal is cheap and any sheet metal shop can rol some beads on it for little to no money. I did floor pans on my friends elcamino this way. It's an 82 no matter what it's not a w30 or w31 where it would justify for me atleast to replace it with a correct piece. Even on my 72 I didn't make a big deal on certain things. Just a plain cutlass s.
For the dent and hole in your floor I also agree that a floor plan replacement may be over kill. The same happened to mine sometime in the past prior to me owning it. I just hammered it back down and patched the small hole.
