engine swap
I'm pretty sure the Electra has a 350 Buick motor. If the distributor is in the front, it's a Buick. The motor mounts and frame mounts are different between the 350 Buick and the 307 Olds motors. In fact, EVERYTHING is different, as they are completely different designs. Exhaust, starter location, accessory location, etc. is all different. The on thing that is the same is the trans bolt pattern. The 79 likely has a TH350 trans. Your Olds likely has a 200-4R (is it a three speed or four speed trans).
It's really not that far off. Key parts you'll need to source will be engine frame mounts from a Buick powered 78 and newer Buick Regal and exhaust system mods to tie in the exhaust manifolds. Use all the buick engine accessories. Every thing else you need will be on your pull out Buick engine.
Henry
Henry
Henry
