Distributor Vacuum control switch
Old Aug 12, 2011 | 12:21 PM
2Cutup's Avatar
Does anyone know where I can get the Distributor Vacuum control switch for a 1972 Olds Cutlass with plug on the top.
Old Aug 12, 2011 | 12:48 PM
Tony72Cutlass'S''s Avatar
You'll have to get one off someone that has an extra, they dont make repros last time I checked, is your car missing one? You could just connect your distributor to potted vacuum thats what alot of folks have done. All the dvcs does is kick in the manifold vacuum to prevent overheating. But I'm sure there are varied opinions on having one installed.
Cheers,
Tony
Old Aug 12, 2011 | 01:11 PM
2Cutup's Avatar
Thanks Tony,
That's the problem I can't find anyone that has it. All aftermarket. My Cutlass is not overheat but the temp is a little high and I'm not sure if it's the duration of the cam or this switch. Only happens at idle.
Old Aug 12, 2011 | 02:33 PM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Old Aug 12, 2011 | 03:33 PM
They are getting scarcer to find. Occasionally they are on ebay. If you hear about someone scrapping a 71 or 72 Olds with a 350 or 455, those are the only years I believe you'll find them on. We have 3 members who actively part cars. You might want to contact them and ask? Here are the links to the 3 that I know:
https://classicoldsmobile.com/forums...dspackrat.html
https://classicoldsmobile.com/forums...s/2blu442.html
https://classicoldsmobile.com/forums...nracing77.html
Good luck with your search. This is what you're looking for:
Originally Posted by Tony72Cutlass'S'
You'll have to get one off someone that has an extra, they dont make repros last time I checked, is your car missing one? You could just connect your distributor to potted vacuum thats what alot of folks have done. All the dvcs does is kick in the manifold vacuum to prevent overheating. But I'm sure there are varied opinions on having one installed. Cheers, Tony
It also advances timing when the car is in 3rd gear.
chyene
Feb 24, 2015 03:52 PM
davoaz
Dec 14, 2014 09:08 AM
ddd777
Apr 10, 2013 05:55 AM
bonnevillegreg
Apr 15, 2012 01:38 PM
New'n72
Mar 6, 2008 03:13 PM
