Dipsticks and headers
Old Mar 22, 2017 | 07:38 PM
elawrence's Avatar
Unhappy Dipsticks and headers
So I have a 71 supreme with a 455. Its had some work done to it. I have installed the larger 1 7/8 Dougs headers and now I'm having trouble with the dipstick. 1. it will be resting on a header tube and 2. getting it pressed into the hole on the block. Any ideas? Saw an earlier post were the guy isn't using a dipstick. It seems I am trying to stuff 10lbs of s*** in a 5lb bag. The entire assembly barely fits in the frame.
Old Mar 22, 2017 | 08:13 PM
steverw's Avatar
I had to very slightly grind a VERY small amount of metal off around the flared section of the tube to get it into my block.Its now a snug fit, but wasnt so tight that i ruined the tube getting it in. If you do the same, perhaps you can bend it slightly so its not against the header.
Old Mar 22, 2017 | 08:37 PM
The tops of the tube being close to the header is not an issue.
Old Mar 22, 2017 | 09:17 PM
elawrence's Avatar
The dipstick tube is actually riding hard on the header tube. I'm worried about the excessive heat working its way down to the pan. Maybe I'm over thinking things. Thanks guys.
Old Mar 22, 2017 | 09:36 PM
svnt442's Avatar
I don't that I would worry about it all that much. With the manifolds it is between the manifold and the head, so it gets plenty hot from the factory.
Old Mar 23, 2017 | 07:45 AM
You are WAAAAAY overthinking this. Stop losing sleep over it. The oil is being splashed on the underside of the hot pistons inside the engine. The amount of heat conducted down the dipstick tube is negligible.
Old Mar 23, 2017 | 01:15 PM
TripDeuces's Avatar
A crows foot wrench or an open end wrench with a helper is one way of driving it home into the block.
Old Mar 23, 2017 | 04:31 PM
cdrod's Avatar
Rodney
Installing dipstick tube with headers
I'm new to headers, but will be installing a set on my project. The headers have a continuous flange, where the exhaust manifold has a notch for the dipstick tube. Do you install the dipstick tube after the headers are installed? Thanks!
Rodney
Old Mar 23, 2017 | 04:34 PM
Rodney
Yes. The real trick is pulling the tube out of the block without breaking it.
Old Mar 23, 2017 | 04:56 PM
elawrence's Avatar
With my headers I had to file a small groove in the flange to get the dipstick tube to go through. Thank you all for your help. My mind is at ease
1965olds
Feb 15, 2014 03:38 AM
Wyze
Mar 18, 2012 01:59 PM
MrLightning
Feb 21, 2012 02:26 PM
TOONLOVESCHERYL
Apr 7, 2011 10:38 AM
martine
Feb 13, 2007 11:57 AM
