Cracking noise when convertible top is let down (72 Oldsmobile Cutlass Supreme)
Old August 21st, 2016 | 08:13 AM
LJ72Cut's Avatar
I have a 1972 Convertible Cutlass Supreme and whenever I let the top back I hear a crackling noise. I am wondering is this normal for this make and model. I know someone who has 75 convertible delta 88 and I hear no cracking noise when they let their top down.
Old August 21st, 2016 | 08:17 AM
Did you used to have a glass rear window? Har har har har.
But seriously, folks...
When I had A-body convertibles, I never heard any cracking sounds when lowering the top.
Old August 21st, 2016 | 08:47 AM
LJ72Cut's Avatar
I don't know what came on the car originally from GM but when I purchased it the guy had a plastic curtain and vinyl top. Then I put a canvas top with a glass curtain. The guy that I know with the delta88 has a vinyl top with a glass curtain but he is missing the curtain.
LJ72Cut's Avatar
Also, the guy at the interior shop told me that my frame was good and not bent. I got a new pump and lines as well.
Old August 21st, 2016 | 09:20 AM
No, I don't think that is normal.
Old August 21st, 2016 | 02:00 PM
Sampson's Avatar
I had something similar on mine. Solved it with this bolt and pivot set from TPP.
The nylon bushings were worn.
Product Name Price Quantity
CV7514Z (1968 - 1972 Cutlass/442) CONVERTIBLE TOP PIVOT BOLT SET - INCLUDES NYLON WASHERS, SHOULDER & WASHER STYLE BOLTS AND BUSHINGS $59.00
Old August 21st, 2016 | 02:10 PM
LJ72Cut's Avatar
Sampson thank you very much for the tip. Were they easy to install?
Old August 21st, 2016 | 02:28 PM
Sampson's Avatar
Old August 21st, 2016 | 06:37 PM
Sampson's Avatar
It was not too hard. I did one at a time. You have to be a bit of a contortionist to get to some of them. All my bolts were good but there was some slop in the nylon bushings. Good luck.
Old August 22nd, 2016 | 08:13 AM
LJ72Cut's Avatar
Lol a contortionist. Ok I will have to get back there and see because I'm not sure how the nylon bushings look.
63super88
March 31st, 2014 02:46 PM
gearheads78
October 31st, 2010 12:31 PM
wjustinmartin
April 9th, 2010 09:51 PM
nukesec1
March 27th, 2010 02:29 PM
Quick Reply: Cracking noise when convertible top is let down (72 Oldsmobile Cutlass Supreme)
