A/C not blowing out vents only bottom of dash (72 Olds Cutlass Supreme)
Old August 8th, 2016, 04:15 PM
LJ72Cut's Avatar
I have a 1972 Oldsmobile Cutlass Supreme and my air does not blow out my vents but sounds like it's blowing out the bottom of the dash. I checked behind my AC/Heat control panel and it looks as if a vacuum line is missing. However, I am not sure if that vacuum line controls the air to the vents and if so where does it feed from. I have attached a picture. Any feedback will be appreciated. Thank you.
LJ72Cut is offline
Old August 8th, 2016, 05:09 PM
There is a vacuum reservoir on the engine side of the firewall that looks like a black ball. There should be two vacuum lines connected to it: source vacuum from the intake manifold and another line through the firewall to the AC controls. If you lose vacuum on this, the air flow defaults to the heat (floor) position.
Fun71 is offline
Old August 8th, 2016, 08:20 PM
oldspackrat's Avatar
Fun is correct, check there first. In your picture the nipple with no hose on it is supposed to be like that.
oldspackrat is offline
Old August 9th, 2016, 06:10 AM
The flapper door that directs airflow among the bottom, dash, and defroster vents in the under-dash HVAC box is operated by a vacuum actuator bolted to the end of the HVAC box near the accelerator pedal. The vacuum switch on the control head is what supplies vacuum to this actuator, so without the hoses connected properly, the system defaults to floor-only airflow. I suggest you get a Chassis Service Manual and look at the vacuum diagrams in Chapter One.
joe_padavano is offline
Old August 9th, 2016, 06:28 PM
LJ72Cut's Avatar
Thank you for your help. After further investigation I realized that I do not have the Vacuum Reservoir at all. I will be ordering that today. Thank you Fun71.
LJ72Cut is offline
Old August 9th, 2016, 06:29 PM
LJ72Cut's Avatar
And thank you oldspackrat and joe_padavano for your help as well.
LJ72Cut is offline
Old August 9th, 2016, 06:57 PM
Glad to help. I have several good ones, $30.00 shipped for one.
Old August 9th, 2016, 07:44 PM
Junkman's Avatar
Be very careful when removing an old rubber hose from the canister. I cut it down the center of the rubber hose, and then peal it off the plastic nipple. I broke one trying to pull the hose off, and learned an expensive lesson. Rubber hose is a lot less expensive than a new canister.
Junkman is offline
Old August 11th, 2016, 07:52 AM
LJ72Cut's Avatar
Thanks guys. Can you let me know which of these below will work? I was told by a summit rep that 47077 would not work for my car but this is the only part that comes up when i search for a Vacuum tank reservoir for that vehicle. Also, I found a different vacuum tank on ebay. I can't find a clear picture of one.
1.(Model 47077) http://www.autozone.com/engine-manag...mpid=PS:3:1:60
2. (Model 47076) http://www.autozone.com/engine-manag...uestid=3252553
Ebay find:
http://www.ebay.com/itm/60s-70s-Olds...FWPSUy&vxp=mtr
LJ72Cut is offline
Old August 11th, 2016, 08:03 AM
There are one-port and two-port versions of the vacuum reservior. Either one will work if connected properly. The two-port has a built-in check valve. The port with the check valve goes to the intake manifold vacuum tap, the other goes to the HVAC system. The one-port design requires an external tee with a built in check valve. Yours came with a two-port reservoir from the factory.
Old August 11th, 2016, 10:49 AM
LJ72Cut's Avatar
Thank you Joe.
LJ72Cut is offline
Old August 11th, 2016, 10:50 AM
LJ72Cut's Avatar
Oldspackrat...do you have any pics?
LJ72Cut is offline
Old August 17th, 2016, 03:11 PM
LJ72Cut's Avatar
I bought the below vacuum reservoir and tried to see if it would mount up right, but it does not have enough clearance over the transmission dipstick tube. Oldspackrat do you still have any available?
LJ72Cut is offline
Old August 17th, 2016, 03:40 PM
Sorry, I missed your first post about requesting a picture. I'll do my best to get one tomorrow.
Old August 18th, 2016, 05:00 AM
LJ72Cut's Avatar
Oldspackrat....thank you. I'm still worried about the clearance of my transmission dipstick tube. It appears that it sits up too high. I've looked at other 72 Olds motors and the transmission dipstick tube appears to be a lot lower than mines. Is there anything I can do about this?
LJ72Cut is offline
Old August 18th, 2016, 05:03 AM
I will look at some of my cars today and see how they compare to yours.
Old August 18th, 2016, 05:34 AM
ddd777's Avatar
Ebay find:
Buy it from Scott (oldspackrat).
It will be correct.
My 2 cents.
ddd777 is offline
Old August 18th, 2016, 04:56 PM
Here is an original 455 th400 car, it looks like your dipstick tube sticks up to far? Also a correct if dirty, vacuum bulb.
Old August 18th, 2016, 07:42 PM
LJ72Cut's Avatar
Oldspackrat......looks good. Does it still function properly and can it be cleaned up with some soap and water? if so..how would I purchase this from you? Also, can someone tell me what the box is circled in red below? I have the adjacent black box (junction box) but not the silver box right next to the vacuum tank in the pic. Also, I called OPG and they told me that my vehicle came with either a 34 or 27 inch dipstick tube so I ordered a 27 inch (I hope this fixes the clearance problem). I measured the dipstick on the one I have already and it was 30 inches so i'm assuming this was not the correct dipstick and tube for my turbo 350 trans and for my cutlass. Thank you for the pics Oldspackrat.
LJ72Cut is offline
Old August 19th, 2016, 02:11 AM
... can someone tell me what the box is circled in red below? I have the adjacent black box (junction box) but not the silver box right next to the vacuum tank in the pic.
That's a voltage regulator. Presumably your car has an internally regulated alternator now.
MDchanic is offline
Old August 19th, 2016, 05:51 AM
LJ72Cut's Avatar
Eric, thank you very much I did switch from an old manual carb to an electric Holley 600 one.
LJ72Cut is offline
Old August 19th, 2016, 05:53 AM
LJ72Cut's Avatar
ddd777 will do. Thanks for the advice.
LJ72Cut is offline
Old August 19th, 2016, 06:00 AM
Ummm... Alternator.
MDchanic is offline
Old August 19th, 2016, 06:08 AM
ddd777's Avatar
Painted mine with some black Krylon. It's bit shiny, compared to the rest of the compartment, but that's OK. It will blend in soon enough.
The wrong kind of screws were used. Need to figure out what the correct ones are and rectify that situation....
vacuum - repainted
ddd777 is offline
Old August 19th, 2016, 07:33 AM
ddd777,
I have the correct screws for the vacuum bulb. Pm me your address & I'll get them on the way?
LJ,
I have several of these & will make sure you get a functional one that will clean up just fine. I would start with the least aggressive method to clean it such as soap & water & a wash cloth. You can always try a plastic bristle brush if it does not want to clean up. As far as payment, I'll pm you shortly.
Old September 2nd, 2016, 07:59 PM
LJ72Cut's Avatar
Originally Posted by MDchanic
Ummm... Alternator.
Yea sorry I overlooked that lol. But I have an aftermarket alternator that I picked up from Summit.
LJ72Cut is offline
Old September 19th, 2016, 07:35 PM
LJ72Cut's Avatar
So I just installed my new 27" transmission dipstick tube and I still do not have enough clearance for the vacuum reservoir tank. The vacuum tank can mount up to its respective holes but once it does that it sits right over the dipstick tube with probably an inch clearance. Which makes it impossible to check my trans fluid because the tank would be in the way. Can anyone shed light on what maybe the problem? i was thinking about putting it higher up on the firewall but wanted to know would that be frowned upon if i used some self drilling nails to put new holes in the firewall so that the tank will sit higher than where it originally was suppose to sit. Also, can anyone tell me what is the correct height/length of the transmission dipstick tube that came with the 72 Olds cutlass. I'm thinking I need a 24 inch dipstick tube. Or just getting a flexible stainless steel one that mounts to the firewall but I would prefer the original look.
LJ72Cut is offline
Old January 21st, 2017, 06:35 PM
LJ72Cut's Avatar
Does anyone have a clear picture of where the vacuum line that runs from the vacuum tank to the back of the manifold hook up? I know one line goes from the control panel inside the car to the tank but I was wondering where did the remaining line that hooks up behind the carburetor go. Thanks.
LJ72Cut is offline
Old January 21st, 2017, 06:50 PM
The Assembly Manual would show you the connection point used by the factory, but any manifold vacuum port would work the same.
MDchanic is offline
Old January 22nd, 2017, 08:48 AM
https://classicoldsmobile.com/forums...take-help.html
This is what I have readily available. It's an aftermarket intake but the important stuff is similar to the factory one.
I think the factory intake will also have a small vacuum nipple on a runner behind the carburetor for the air cleaner thermal valve.
Here's a pic of a factory manifold. One of the small 90º nipples behind the carb pad is for the vacuum reservoir.
https://classicoldsmobile.com/forums...-manifold.html
SEARCH and Chris Witt are your friends:
Fun71 is offline
Old April 26th, 2017, 07:30 PM
  #31
LJ72Cut's Avatar
How do I know what size vacuum line to use? Do they come in a pack with diff sizes?
Also, which vacuum line in the above pic do I trace through the firewall and place on the nipple of the vacuum tank reservoir (the black one or the white/black one)?
LJ72Cut is offline
Old April 27th, 2017, 04:45 PM
  #32
LJ72Cut's Avatar
Also, there is nothing present where the A/C Vaccum Reservoir is. Am I missing the Vaccum Actuator or Vacuum check valve?
http://www.oldairproducts.com/catalo...sF85&Year=1972
LJ72Cut is offline
Old April 27th, 2017, 06:06 PM
  #33
The vacuum reservoir similar to the one pictured below from your web link should be mounted on the firewall and have a small diameter vacuum hose (1/4" maybe?) connected to the nipple on the intake manifold labeled AC Vacuum Reservoir in the picture.
As for vacuum hoses, they can be purchased at the local hardware store. I am not certain of the exact size needed but if you have a caliper, micrometer, or precision ruler you can measure the diameter of the port and get a hose with that inside diameter. Or get a small piece of hose from the store and test fit it on the port. It will be the right size, too bit, or too small. Go from there.
If you don't have the reservoir above, once you get one you can bring it to the parts store and try hoses until you get the ones that fit on the reservoir nipples.
If you have on on the firewall, take it off and bring it to the parts store to try fitting the hoses.
Fun71 is offline
Old April 29th, 2017, 01:20 PM
  #34
LJ72Cut's Avatar
I have the vacuum tank (seen below) mounted to my firewall however where im assuming the AC vacuum reservoir is located on my manifold I don't have a nipple to connect any vacuum lines to. This is where the issue lies I don't know where to connect the nipple from the vacuum tank to the manifold.
I have circled where I assume the AC Vacuum Reservoir is located on the manifold but as I stated earlier nothing is here.
LJ72Cut is offline
Old April 29th, 2017, 03:39 PM
  #35
That's the boss where the coil screws on.
You can connect the A/C reservoir to any manifold vacuum fitting.
MDchanic is offline
LJ72Cut
August 19th, 2016 11:14 AM
tdhill01
April 29th, 2014 06:25 AM
442NDTSS
August 3rd, 2012 02:30 PM
lvelocci
Body work
November 15th, 2010 11:05 AM
lvelocci
Body work
November 14th, 2010 06:06 AM
Quick Reply: A/C not blowing out vents only bottom of dash (72 Olds Cutlass Supreme)
