Bought a 1963 Oldsmobile F-85 Convertible that had been sitting for years
![](https://cimg1.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/30731cdc_cc9d_4a03_888a_0b19b19f2c1b_7aff6eafa72dfe38b474849b18e4f50557a80db5.jpeg)
![](https://cimg2.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/cddd9419_d2f9_4fed_839e_993f6bd80962_83bd2cb2a5a5845f13b49591a77aade3d58604ab.jpeg)
![](https://cimg3.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/8146a872_344c_41dd_b590_ab3863e96c9a_9c4a7781a244ca02f0c309e7620ef710ed5add9e.jpeg)
![](https://cimg4.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/6515196a_8eb5_4f2e_bbda_41e1283892f5_59b109b4104f6b4368b1d95893555905afb22812.jpeg)
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/27c967f0_9f76_4363_b645_aca3da468641_c43a327ff1fdf172f478a1467fc2ac812f78a7b0.jpeg)
![](https://cimg6.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/ca7da239_2932_4ecf_98a0_65ecfee3bdc2_48a13985fc33fffb9d7933030258a34c2b3e189a.jpeg)
![](https://cimg7.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/c79727cf_299f_49c2_8722_13f5247a7e26_db9e402ccacec63ed0f47e3239ee87071f2619ed.jpeg)
Recently picked this car up from a local family where I live. Honestly I feel like a picked it up for a great deal. Body, paint, interior, chrome/trim, window/Door seals all in excellent condition. The problem is it’s been sitting, so of course there are various leaks etc. Made sure everything was full on fluids before the start and she fired right up, initial test drive it hesitates to shift from 1st and seems to misfire before it shifts but once it does it lurks forward and seems to do fine from there, although there is a rattle sound, kinda like letting the clutch out on a standard trans in too high of a gear. although rough at first. So I begin walking through things, change the air cleaner, plugs and wires, check compression and it’s at 140. Problem is it still seems to have a miss or dead cylinder. Any advice on more to check.
Looks like a nice score!!! My first car was(except for the color) just like yours. Cutlass convertible ,buckets, auto console, 215 4bbl. Mine was light blue with a black interior. I always had a soft spot for these cars!! You'll want to get with Eric Jensen on this site( jensenracing77) He's doing an unbelievable!!!! resto on a '62 Jetfire. His work is amazing & he really knows these cars!!!! Good luck with finding your engine miss fire. Hopefully some new tune up parts will fix it. Check for vacuum leaks also. At least your compression looks good.
That car is beautiful. As a data point, my 62 F85 wagon had sat outdoors in the Nevada desert for years. I replaced all hoses, rebuilt the brakes, and flushed the gas tank (which ended up being amazingly clean inside). One thing I found is that a number of the electrical connectors needed to be disassembled and thoroughly cleaned to eliminate intermittent electrical problems. I've been driving the car for over ten years now. I've eventually had to rebuild the front suspension and steering, and do some work to get the e-brake functioning. I drained and refilled the Roto5 trans, and it has been working reasonably well (for that trans) but it's getting to the point that I need to replace it.
For sure drain the transmission and refill. My transmission guy told me that he would prefer I use type F in these transmissions. These transmission pans have a drain plug on them so it makes it easy to do. Filters can be difficult to find but they are large enough that you would likely be ok to just replace the fluid for now. These transmissions have a funny 1-2 shift even when they are working right. If it sit that long there is a good chance it is going to need some brake work. For safety alone I would rebuild the master cylinder and wheel cylinders. EVERY 61-63 I have had needed the brakes worked on when I got it.
Welcome to CO and nice find!
When you said "sitting" I expected to see a dusty crusty car that had been dragged out from behind a barn. That thing is nice!
Get used to the funky shift. The Roto 5 trans is every bit as quirky as its big brother Roto 10 that was used in the big cars.
TimMC
August 1st, 2023 11:50 AM
70-442-W30
August 8th, 2017 09:32 AM
