Art 72 Cutlass
Art 72 Cutlass
Hi, I'm new to the forum. I am in the process of getting the 1972 Cutlass full service manual, but in the mean time, I have a question. Is the cigarette lighter on its own fuse. Right now mine is not working. All other lights work. I want to use it as a cell phone charger. Any help would be appreciated.
I don't remember if it has it's own fuse or not. I'd start at the fuse box. Use a test light to check both ends of the fuse for power. Some of them may not be hot unless the key is in the run position, or unless the lights are on. Also look for rust between the fuse & the fuse holder. I had that before where both ends of the fuse were hot, but the little fingers that hold the metal ends were not due to rust between the two. If rust, a little sand paper or flat screwdriver should remove it pretty well. If all fuses are good, remove the woodgrain around the speedo, & fuel gauge. There are 2 screws above it & 2 below it. Then remove the pod on the right side. It's held in with 3 1/4" screws. I bet it has come unplugged. There should be an orange wire wit a female connnector just inside that hole & to the right a little bit maybe. The back of the lighter element has a small nipple, maybe about 1/4" long that the orange wire slips onto. It's not a real good connection to begin with. If that's the case with yours, you can "gently" close the connector with a set of pliers & slip it back on the lighter.
Let us know what you find.
Here you go - right out of the 72 CSM
![](/forums/attachments/newbie-forum/62388d1360810353-art-72-cutlass-fuse-block-72.jpg)
You are the man oldspackrat, based on what you told me and the fuse panel print that Allan R sent me, I knew it wasn't the fuse because the lights work that use the same fuse. So I proceded to follow your next instructions. I removed the bezel and the right pod, sure enough the orange wire had popped off. I squeezed the connector a little bit and re-inserted it on the lighter post. Sure enough the thing works! Thanks to everyone for the help!
Art72
Art72
Really nice looking car. Is that Flame Orange (65)? Usually when the W29 appearance is added, the side moldings are deleted. The side stripes actually should be 3 stripes instead of 2 though. Wheels look great, like the way the car remains badged as a Cutlass S instead of 442. But, it shore ain't no Hurst Olds!(trunk emblem)
I see the AC has been deleted. Bet that thing runs like a scared rabbit!
Yes it's Code 65 (Flame Orange). It is the paint code on the trim tag. I guess whoever ordered the car wanted the side moldings too. As far as the Hurst emblem, it was on there when I got the car. Thanks
mmm, no. From the factory if the car was ordered with a W29 appearance package the side moldings were automatically deleted and the car was pierced for 442 emblems as well. Indicator of Cutlass S build instead of W29 442 is also seen on the hood. The W29 had the Oldsmobile script mounted on the DS hood lip area and the grill was badged 442. The grills on the car have been changed from the original horizontal S horizontal pattern. Only BBO W30's actually got the dual cutout bumpers so the one on there was added by the PO too. No matter - I love the look of dual cutouts and the 442 grills.
Noteworthy - in 72 442 lost its distinction of being a separate model. Exterior emblems (fender, trunk deck, grill) would show 442, but interior glove box and door emblems would remain as "Cutlass" or "Cutlass Supreme" on the verts. 1972 Cutlass models are the easiest to clone into 442's because of the change to VIN coding. Only real way to know if the car was originally a W29 is through documentation (build sheet, broadcast card, original BOS or window sticker).
Most likely the PO just decided to customize the car the way he wanted it with the striping. FWIW the body side moldings that were left on are the upgrade ones that have the black overlays - not that commonly seen nowadays. Easier to remove a stripe than weld on those molding clips. The moldings weren't all that functional - still got lots of door dings in spite of that when I got my first 72 back in 74.
I think you've got a gorgeous car; and know you'll have a great time driving it. I encourage you to learn more about your car by reading through the site, and also documentation on Olds.
If you want the 71 grills? Check with John McNeel (2blu442). He probably has some sitting around and he always is fair in pricing and shipping. + he's close - Medford Oregon.
