Alternator for 72?
Old Aug 7, 2012 | 04:14 PM
mefirst72's Avatar
Alternator for 72?
Hey All
Need to replace my current, stock Delco Alternator (63 amps I believe?)
Doing some research and came across the Powermaster, 10si series http://www.powermasterperformance.co...r_7127/286/c48
Could with with more amps, but this seemed to get some pretty good reviews(?)
Any reason to go higher? Not really adding anything that would require more amps.
Also, any other sources or thoughts about Powermaster?
Thanks. Appreciate it!
Old Aug 8, 2012 | 07:25 AM
hookem horns's Avatar
If you have the stock original, have it rebuilt. If not, I bought a stock style remanufactured one for around $60 at O'Reilly's with a lifefime warranty. Good enough unless you start adding amps to the stereo, electric fans or some other big power draw.
Old Aug 8, 2012 | 08:36 AM
bccan's Avatar
Just a heads up-
On a '72 be sure whether it has an internal or external regulator. I have run into these where the unit appears to be an internally regulated type but doesn't actually have it in there, it still uses an external regulator on the firewall.
If it is original to the car, I would lean towards having it rebuilt if there is a shop near you. 63A is ample if you don't have a big stereo, electric fans or other high draw items not in the plan back in the day.
Old Aug 8, 2012 | 09:47 AM
brown7373's Avatar
I posted an almost identical question about upgrading my 72's 57 amp alternator to a 63 amp about a month ago. My answer was it would cause no problems, just give me a little more charging capacity.
I bought a remanufactured 63 amp from NAPA. Looks brand new and I have never had any issues with NAPA parts, new or remanufactured. About $60 after tax, freight and core refund.
BILL DEMMER's Avatar
Just the facts...
i'd rebuild the original if there's no need/desire to change things.
bill
Old Aug 8, 2012 | 07:03 PM
mefirst72's Avatar
Thanks Dane, much appreciated!
Old Aug 8, 2012 | 07:04 PM
mefirst72's Avatar
Thanks Bill! Just wanted to make sure
Old Aug 8, 2012 | 07:05 PM
mefirst72's Avatar
Brown 7373...Thanks. Always glad I'm not the only one. Very new to the "car" world, mostly been around motorcycles.
Old Aug 8, 2012 | 07:18 PM
72 alts were either 37, 55 or 63 amps. If you're not adding options or equipment to the car? Staying with stock amp is fine. I'm adding a lot of accessories so I upgraded from 37 to 63. Until the current is needed, the 63 amp works just fine in place of the 37.
Old Aug 8, 2012 | 07:19 PM
mefirst72's Avatar
Thanks Bccan for the heads-up.
Whats the best way to determine if it's internal or external? How and where the connections come in?
I don't see any external boxes on the firewall. If I posted a photo, do you think you could help out, be able to tell?
Old Aug 8, 2012 | 07:20 PM
mefirst72's Avatar
Thanks Allan R!
Old Aug 8, 2012 | 07:46 PM
mefirst72's Avatar
Current Alternator
Some current shots
Assuming this is an External Alternator?
Old Aug 8, 2012 | 08:44 PM
Highwayman's Avatar
Yes, it's external when the two spade connectors are parallel. ( I I )
The internal regulators have spade connectors inline. (– – )
Old Aug 8, 2012 | 08:55 PM
henryk8398's Avatar
Hangin' out...
You'd be surprised at how much better everything will work if you take the time to clean up various grounds under the hood. If you think your stock alternator has enough amps, I would suggest taking it to a local rebuilder. I think you get a better product than an auto parts store.
If you want more amps, but aren't concerned with looking stock, you can convert to an internally regulated unit from the 80s. That would involve some wiring changes. I think there are kits. The fan looks slightly different, but they provide higher amperage and are easy to find.
I believe the 1985 Toronado with 307 was 94 amps. That's plenty.
Old Aug 9, 2012 | 05:29 AM
mefirst72's Avatar
Thanks All!!
As usual I really appreciate the lesson, and suggestions. This forum and this kind of quick feedback is pretty amazing...thanks again
442mark
Sep 30, 2017 01:06 PM
Alocatelli
Aug 4, 2016 05:55 AM
Redog
Aug 29, 2007 02:20 AM
2 door cut
Jun 10, 2007 02:16 PM
Pete77
Jul 4, 2006 08:58 AM
