Adjusting sagging doors...
Old Aug 18, 2009 | 12:13 PM
dallasite21's Avatar
Does anyone know how to adjust the doors so they will raise op just a little. They seem to be off slightly and when I close the door the metal from the outer lip of the door is rubbing slightly agains the start of the rear quarter. Is ther an adjustustable part of the hinge that will allow the door to be set a little higher. I have a 1971 Cutlass Convertible.
Old Aug 18, 2009 | 12:16 PM
Oldsguy's Avatar
Past Administrator
Probably just worn hinge pins and bushings. Most auto parts stores have them in stock. Can you lift the end of the door slightly when it is extended out? If so, they are worn. If not, then you do probably need to adjust the hinges themselves.
Old Aug 18, 2009 | 12:35 PM
Oldsmaniac's Avatar
The catch bolt is adjustable on the post where door latches. You can adjust this up and it will compensate a little for worn hinges. Most have an allen recess for loosening with an allen wrench.
Old Aug 18, 2009 | 12:39 PM
68Tom's Avatar
I personally think it's just a good idea to replace the bushings. It's not too terribly difficult and can be done over a weekend. Just make sure to mark where the hinges were located on both the door and the car body. This way, you won't have to spend much time realigning your doors.
Old Aug 18, 2009 | 12:56 PM
Yes, I can lift on the ddor and ther is a little play. That is what seems to be the problem. I will look fo rthe pin and the bushing at autozone. Thanks
Old Aug 18, 2009 | 12:57 PM
Sorry about the spelling. I have a wireless keyboard and the batteries are low.
halfmoontrail
Feb 22, 2013 12:14 PM
projectheaven
Suspension & Handling
Jan 4, 2012 09:32 PM
Olds Dad
Body work
Oct 15, 2010 11:50 AM
case2273
Jul 16, 2009 02:02 PM
pakrat
Body work
Jul 11, 2009 10:20 PM
