77 Olds Cutlass
Here's an interesting link you can browse through for general info. http://auto.howstuffworks.com/1973-1...rmediates5.htm
455
Although 455's were never offered in a Cutlass in 77, (76 was the last year they made 455's for the Cutlass/442 line) they did offer a 403. The engine mounts and tranny for a 350 should bolt up no problem to a 455.
I'm countin on your knowledge as I can pick up a 455 locally, so now I'll do it. Thanks.
The engine is a 455 as identified by the 396021F.
Joe already provided the info about the heads being swapped out. On a 72 block they should be Ga heads.
What does the other numbers mean? 32 means Olds division 1972 model year, m means the engine was built in Lansing Michigan, and the other digits are the last 6 numbers of the original cars VIN.
see sample below
see sample below
