73' OMEGA 350 rocket headers?
I'm looking to add headers but I'm lost when it comes to finding out exactly what type will fit to my engine/engine compartment. PLEASE HELP QUICK! The mechanic rebuilding my engine will be at my house in two weeks to drop it in and I'm looking to own the headers before then
The X-body front frame is very similar to the F-body front frame. That being said the same headers fit a 73-77 Cutlass 350-403 that fit a T/A 403. So I would surmise that any SBO header that will fit a T/A with a SBO or a 73-77 Cutlass SBO SHOULD fit the X-body SBO.
YMMV.
YMMV.
That's true for 1975-79 Omegas. Unfortunately the 73-74 Omega used the older style rear-steer front subframe like the 67-69 f-body. The steering gearbox severely restricts header clearance on these cars when fitted with the wider Olds V8.
That is correct, yet the 3104s allegedly fit both the rear steer 73-74 cars and the front steer 75-up cars. Go figure.
When I ordered mine 6 or 7 years ago I got them pretty fast.But I don't think they were 3104 I can't remember the make.I'll look tomorrow I should have the receipt.I think I got them from summit.FyI if I remember right I had them on and had to take them off to get the motor in.It's very tight in there.FYI again a Lot easier to put trany in with the motor than after.
railguy
railguy
1978 Omega Headers needed
I have to piggy bank on this top because I'm lost on what headers to purchase. I got a deal on the 3107 HKR hooker headers but after reading further, I am afraid they won't fit. They will be going on a 330.
Let me get this clear also, Omegas up to 74 are structually different from the 75-79? All the info I have been getting off site on Omega stuff seems to be off of 73 Omegas.
Let me get this clear also, Omegas up to 74 are structually different from the 75-79? All the info I have been getting off site on Omega stuff seems to be off of 73 Omegas. So, all this info should be wiped out for me?
The 1973-74 Omegas are the same. The 75-79 use a different subframe, different steering, etc.
455 omega
i am planning on doing a bbo in my 74 omega . i am almost ready to do a test fit to check heater box and hood clearence.i was just told cast iron ex manifold may touch the gear box and maby using a metric 78-87 g body gearbox will help . this was maby smaller and would clear ?? does any one out there know ?? i want to stay away from HOT headers and use cast. but will use what will work .any help would be great thanks .
The G-body steering box is exactly the same size (and casting) as the Omega box. The only thing about it that's "metric" is the tube fittings. There is no clearance benefit from switching.
do you think it will work on a big block ? i called mondellow and they said they make a custem set for 73-74 omegas w a bbo . but i was screwed over before by them . i would prefer cast ,maby 307 toros ? thanks steve
The taller deck height of the BBO would require SBO headers to be modified. I don't understand what 307 Toro manifolds have to do with anything.
74 Omega with 350 Rocket.
railguy
Attachment 95073
Attachment 95074
Attachment 95075
Attachment 95076
railguy
Attachment 95073
Attachment 95074
Attachment 95075
Attachment 95076
Ok I did a search and found this old thread. I have a customer that originally wanted me to build him a 455 for his 73 Omega. I thought they may be a tight fit so I convinced him to go with a 350 SBO. So, are there any headers that will fit a 73 Omega with a 350 SBO? This car was originally a 6 cylinder car.
Thanks!
Thanks!
Thanks!
Thanks!
