72 Cutlass Supreme windshield wipers only work on one speed
Old May 28, 2018 | 09:52 AM
LJ72Cut's Avatar
My windshield wipers in my 72 cutlass only operate on the highest wiper speed and not the lower one. Does anyone know the reason for this? I知 assuming it may be the wiper switch but I知 not sure.
Old May 28, 2018 | 11:13 AM
Originally Posted by LJ72Cut
My windshield wipers in my 72 cutlass only operate on the highest wiper speed and not the lower one. Does anyone know the reason for this? I’m assuming it may be the wiper switch but I’m not sure.
Your Chassis Service Manual has a whole section on troubleshooting this problem. The round GM wiper motor uses a shunt winding design to get low speed. The shunt winding is wound in the opposite direction from the high speed winding. To get high speed, only the high speed winding is powered. To get low speed, BOTH the high speed and low speed windings are powered. Since the shunt winding is in the opposite direction, it partly cancels out the magnetic force of the high speed winding, which then gives you low speed.
Anything that prevents the shunt winding from being powered can cause this. It could be the switch, the wiring to the motor, the connectors between the switch and the motor, or the motor itself. This is why you need to follow the troubleshooting procedure in the CSM to avoid replacing parts that aren't bad.
LJ72Cut
Aug 21, 2016 02:42 PM
bainer1290
May 19, 2016 06:58 AM
Octania
Jun 15, 2015 10:00 AM
jlelec
Jul 5, 2014 10:28 PM
ramairthree
Jul 4, 2013 02:32 PM
