72 cutlass supreme
Old Sep 19, 2009 | 10:37 PM
smknjoe1's Avatar
Question 72 cutlass supreme
Well just got a 72 cutlass w/350n350 trannie. Car is n bad shape but is complete. Restoration is going good........My ? is what do i need to know about swappin the 350 to 455 in also a bigger trannie. motor mounts tranmission mount etc.
Old Sep 19, 2009 | 11:45 PM
svnt442's Avatar
Use replacement 350 engine side mounts and the 455 drops right in. With a TH-400 trans (short tail housing) you just slide the cross member back. The holes are already in the frame for it. You will need a shorter driveshaft and a TH-400 yoke. There may be an issues with the parking brake cable, but I'm not sure about that.
That's about it.
Old Sep 20, 2009 | 03:29 AM
Welcome
Welcome aboard
Glad you decided to join us.
Old Sep 20, 2009 | 07:30 AM
That's about it.
You are correct. Since the e-brake cable hangs off the crossmember, moving the crossmember requires a longer front cable and a shorter intermediate cable.
Old Sep 20, 2009 | 03:02 PM
citcapp's Avatar
Talking Welcome to CO
This is a straight foward swap as mentioned above. Good luck and keep us posted
Old Sep 20, 2009 | 09:40 PM
smknjoe1's Avatar
so motor mounts would have to be changed
Old Sep 20, 2009 | 09:53 PM
svnt442's Avatar
No they wouldn't. Just get new replacement mounts for the 350 NOT the 455.
It's always a good idea to replace the motor mounts when you have an engine out of the car.
Old Sep 20, 2009 | 10:38 PM
smknjoe1's Avatar
okay thank for the help
Old Sep 21, 2009 | 11:11 AM
#1CutlassSupreme's Avatar
If you're going with the 455 in your 72' might as well make it look good too and put the 442 grilles in...unless of course you're looking to build a sleeper!
Welcome aboard!
Old Sep 21, 2009 | 02:14 PM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Oldssupreme
Apr 3, 2015 08:36 PM
travisbeamon
Aug 7, 2011 12:51 PM
olds70supreme
Aug 1, 2011 05:22 PM
70_CS
Mar 17, 2009 03:25 AM
72droptop
Jul 27, 2007 07:52 PM
