72 cutlass s I need lots of help!
This place is great! Has helped me a lot. But I still have tons of questions!
How do you install drip rail moldings?
Does anyone have a pic of the vacuum lines are supposed to look like under dash?
Who sells the best patch panels for fenders?
Does some sell repo harness for lighter?
Hope you guys can help!
Drip rail moldings are pretty easy if you take your time. Slide them over the top edge first & then gently push them over the bottom edge. Then do the same thing with the ones on the side of the windshield. The little L bracket at the top is similar but you might have to play around with it a little bit & maybe use a set of pliers to lightly crimp it at each end.
The lighter harness is just an orange wire? with a female connector on it. It should be in your dash harness behind the clock/tach/blank pod, if not, many of us on here can supply you with one.
Good luck!
Scott
Good luck!
Scott
1965CUTLASSHOLIDAY
May 30th, 2010 03:55 PM
