72 cutlass s
Hello.Im tbird.My car is such a mess.I let idiots work on her.I got to looking at allthe wiring,wow! I dont think theres a single wire that isnt spliced.Im surprised she even runs. Shes been my daily driver for 15 years. I couldnt imagine driving anything else.I looked at the chiltons but I need more a more detailed diagram. Any suggestions?
Yes. Throw the Chilton's manual as far away as you can and get a factory Chassis Service Manual for your year. The CSM will have a color wiring diagram in addition to everything else you need to fix the car.
You didn't specify the year, but by the late 1970s Olds started using a separate electrical troubleshooting manual due to the size and complexity of the wiring on these cars.
With my eyes. the larger wiring diagram (plastic coated) from classiccarwiring
http://www.classiccarwiring.com/olds.php
good addition to the very necessary chassis service manual mentioned above...
On the other hand, more cash, but I replaced the headlight wiring harness, and engine wiring harness with new. Just rip the old out and install the new. Plug and play. I used M&M. All color coded to factory and all the factory style plugs. Just plug them in to the firewall side of your fuse block and route them. Note- Easiest to do with the fender off or the brake booster removed. The factory manual shows the routing. For as many years as you have and plan ahead to drive your car, this would be the way I would address the mess you have.
