68 olds Cutlass S inline 6 fluids questions
Old Jul 9, 2016 | 07:41 AM
piersonhouse's Avatar
68 Cutlass S
Question 68 olds Cutlass S inline 6 fluids questions
HI-
Just got into the game with a 68 Olds Cutlass S convertible with the inline 6 cylinder engine. Not sure what fluids I should be using for this engine. I think 10W 30 is recc for the oil but not sure on brake fluid, the automatic trans fluid or what gasoline would run best.
Car is in New Jersey.
Any suggestions would be great !
Glenn
Old Jul 9, 2016 | 08:06 AM
Welcome to the site, post some pics also. 10w30 is fine for motor oil, dot3 for brake fluid, and dextron auto trans fluid.
Old Jul 9, 2016 | 08:20 AM
68 Cutlass S
Thanks for the info and the welcome! I put a picture in the album but can't seem to get one in my profile ;-( I just got the car a week ago and all seems to be running very well and its in beautiful shape. I'm an average mechanic ( brakes, oil changes, minor stuff) but never had an older engine. Also, the 6 cyl seems to be harder to get any info on, since it was a rarer choice than the V8's.
Old Jul 9, 2016 | 08:25 AM
Very nice, got any under hood and interior shots? Here is a link on how to post pictures.
https://classicoldsmobile.com/forums...-pictures.html
Old Jul 9, 2016 | 09:02 AM
68 Cutlass S
Heres some engine shots. Maybe you can answer ...the photo showing the reservoir on the top right of the engine..the cap( which is hard to read) looks like its say Auto Trans Fluid Use Type A....this seem like an odd spot for the trans fluid fill, since the lines running from it go down to the end of the steering column. Is the cap wrong? If so, I'm not sure where the power steering fill and the trans fluid fills are...
Old Jul 9, 2016 | 09:32 AM
That is your power steering pump.
Old Jul 9, 2016 | 09:41 AM
droptopron's Avatar
delete
Pretty sure the engine is a Chevy 250. You may have an easier time finding info referencing that
Old Jul 9, 2016 | 09:54 AM
68 Cutlass S
Thats what I figured. The cap is loose so I thought it might be wrong. I see the trans fluid stick. Do you know where I'd put the trans fluid in?
68 Cutlass S
Yes, thanks for the tip !!
Old Jul 9, 2016 | 10:17 AM
Yes, it's a Chevy 250. Power steering systems then used ATF. Trans fluid goes in the trans dipstick tube at the rear passenger side of the engine. The six is rare because it was unpopular when new. Good luck with it.
Old Jul 9, 2016 | 10:40 AM
68 Cutlass S
Thanks Joe! So use automatic transmission fluid for the power steering? Any particular grade and same ok for both power steering and trans?
Yes on the 6, but oddly the fact that only 410 were built this way is what drew me to it. Its got a new top, interior ( seats and carpet), tires, rims and suspension so nothing much to do to it ( for now). Its always nice to have a V8 but this one was so nice, inside and out, it just seemed right. ...and the shiny red certainly turns heads. I'm super happy with it but its a new learning curve for me with an older car. I feel my knowledge of newer cars needs to be double checked before I do things , especially to the engine. I appreciate the help!!
Old Jul 9, 2016 | 10:47 AM
68 Cutlass S
Any thoughts on the gas I should use?
Old Jul 9, 2016 | 01:50 PM
Sugar Bear's Avatar
VERY nice car!!! The six cylinder makes it quite unique.
Yes to the 10W-30. I would prefer one rated for diesel use, look for a C rating in addition to the S on the bottle to gain some extra protection for the flat tappet camshaft. I would also consider adding some ZDDP to the oil.
Gasoline - Check top tier gasoline online. I use BP premium as it is convenient and fairly priced. Keep the tank full to reduce corrosion and add fuel stabilizer if it sits for long periods. Best practice is to drive it alot!!!
Your questions about what products, grades etc. will make a difference in how the car survives and performs.
wozz
Dec 22, 2013 07:37 AM
fasteddi
Jul 10, 2011 06:16 AM
venividivici53
Oct 15, 2009 10:32 AM
wolfman98
Apr 15, 2009 06:07 PM
tarps3
Ninety-Eight
Oct 18, 2006 07:08 AM
