68 olds
68 olds
Hi all from San Antonio,Tx I purchased a 1968 Oldsmobile Cutlass (my first olds) so looking forward to chatting and working with some of you guys for guidance and to be schooled on my dream. Car came with a 350 motor and 350 trans
Welcome! I have a 68 442 and have gotten more valuable information here than I can possibly convey in a short introduction. You made the right decision joining this group. Everybody here is so nice. Good luck with your Cutlass. You're going to love it.
Chris
Chris
Hi, I too have a 68 Cutlass with at 350/350 combo. The 350TH will not be original. The '68's could have come with a 2 speed Jetway. I am happy with my combo. I am always got my eye open for a 455 but I am in no hurry or need for it. Have fun, there is a lot of information here and opinions. Whatever you do remember it's your car.
_
EDIT: actually, looking through the GM Parts manual it may be the same glass from 68-72 hardtops (not verts or 70-72 supremes) !
It is a 2 dr post coupe. You can tell because all the windows are 'framed. There is also a 'b' pillar between the front door and the rear window. IIRC it uses the same 1/4 glass as the ht coupe though.
I looked at some suppliers like PS Auto Glass. Got my side glass from them and it was impeccable. Maybe try asking them if they have the right glass, or can point you in the right direction. Take a look at this link: http://www.psautoglass.com/store/Scr...idCategory=517 ASK them if this will work for your application.
The reason I believe it is a post? Look at the 'heavy' molding at the top of the window. You don't have that on a hardtop - only posts. I believe the door and rear 1/4 window are fully enclosed by a framework on this car. Naturally, a good side view would be better. I'm going to go out on a limb here and say I'm right though...
EDIT: here's a pic of a 68 post with a vinyl top. Got this from ROP
Lansing 1968 Olds owner
I just found a local 69 post car for parrts
perhaps give a text or call
can get to it maybe thursday or friday this week
Chris Witt
517.449.043two
RocketScience442@hotmail.cam <== change to ".com" before using!
Chris Witt
517.449.043two
Ok guys here is one for u....I think I got everything connected right but the light for the oil jus turns on but the starter wont turn, but if I lift the front end of the car on jacks the car starts right up can anyone help me???? Im guessing maybe a ground wire somewhere
alittle off on value, wish i could find some for 50 - 100 $ - shipping 50 -100 $ sounds more like it. chk these out.
http://www.ebay.com/itm/Olds-head-5-...item4160a0b11b
How about the support/ torque strap/ GROUND STRAP that runs from the side of the starter at the front, to the motor block above? That one got me once. It was a PITA to install so I left it off. It is NOT, as it turns out, totally unnecessary.
