66 442 A/C vents
Old Jun 25, 2011 | 08:09 AM
bobfo1's Avatar
66 442 A/C vents
I need to cut holes in my dash to accommodate right and left side vents for factory A/C for my 66 442. Can anyone help me with a cutting pattern or tell me how I might get one.
Old Jun 25, 2011 | 01:47 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Have you tried to make a pattern from the deflectors.I do this, take some 3 inch or so masking tape and lay it on the backside of the deflector.Using a razor blade cut around the deflector.Do both deflectors.
Pull the masking tape off of the defector and now that can be used as a template on the dash.You can move that pattern for alignment and make sure they are both uniform.
You will need to cut maybe 1/4 of an inch inside if the tape.
Old Jun 25, 2011 | 07:33 PM
Run to Rund's Avatar
I have a 66 body that is stripped so I can make you templates next week when I get to the place where I have the car. PM me your address.
Old Jun 28, 2011 | 08:34 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, be careful cutting those holes.
Jeff70442
Oct 4, 2011 07:20 AM
Tucsonbob
Feb 28, 2011 06:48 PM
a1fla
Jan 25, 2011 08:23 AM
arodenhiser
Sep 28, 2010 01:47 PM
Oldsmaniac
Apr 16, 2010 03:02 AM
