64 2 door hrdtop
Old Sep 21, 2011 | 03:47 PM
royalrods's Avatar
64 2 door hrdtop
I'm new here and just bought this BB and I'm looking for some help .She has some issues that id like to fix . Front bumper is wasted and need a new one also looking for a driver side window track . Please help if you can Ebay prices are crazy . Also looking for a 4brl intake for the 394 or a 3 duece along with a air ride kit. You can contact me directly also at royalsrp76@gmail.com I have a lot of questions.
Old Sep 22, 2011 | 06:41 AM
Nice car!!
Old Sep 22, 2011 | 10:18 AM
Nice car. Be aware that bumpers for the 1963-64 full size cars are impossible to find and are extremely expensive when you do. The design uses a bracket welded to the backside so there are no exposed fasteners. This bracket is perfect for collecting mud, salt, and moisture, so all of them have the two rust holes.
Old Sep 22, 2011 | 10:40 AM
72 cutlass455's Avatar
Welcome
Old Sep 22, 2011 | 12:59 PM
rocketraider's Avatar
Oldsdruid
I was just thinking it's unusual to see a trashed front bumper unless it's bent up bad. The rear is the one that usually rusts thru.
59-64 394 4-barrel intakes are the same. They use a Rochester 4GC carb that can be a mixed blessing. I think an Edelbrock or AFB will bolt up to the factory manifold, you just have to make sure the transmission's throttle valve rod is set properly for the change in linkage. Otherwise you will have a very unhappy HydraMatic that will take its revenge, and there is no modern transmission that will bolt to the 64 engine block without modifications to the case.
I'll have to do some digging on the window track. I think all the 1963-4 GM B-body 2-door hardtops use the same part except the Grand Prix, Starfire and Jetstar I. And it seems I remember the Chevy crowd has reproduced them for Impalas which should fit your Dynamic. Difference may be the Chevy piece is raw metal where the Olds was chrome plated, but if it fits and works, the thing is hidden by the window belt seal.
I'm not aware of any off-the-shelf air suspension kits for the Olds, but I've seen them with bags so someone has figured out how to do it. Impala frames are very different and Chevy bags may or may not work.
Old Sep 22, 2011 | 02:09 PM
Oldsguy's Avatar
Past Administrator
Nice car, welcome to CO.
Old Sep 22, 2011 | 07:11 PM
royalrods's Avatar
Thanks for the info . Do you know the year and models of bumpers will work?
Old Sep 22, 2011 | 07:26 PM
Oldsmaniac's Avatar
This may be a long shot but I just saw a TV show from Desert Valley Auto parts in AZ I think. In their junkyard was a 64 full size with a nice front bumper. You may want to call them.
Old Sep 22, 2011 | 07:45 PM
royalrods's Avatar
Thanks I lived in az for 15 years and if I or any of you want to have a good time " minus lube" it just the place you want . LOL
Old Sep 23, 2011 | 12:10 AM
spiderjason's Avatar
Welcome.... cool car!!!
Old Sep 23, 2011 | 06:57 AM
Glenn, I'd be happy to show you the rust holes on the front bumper of my 64 J88.
It's the same bracket design as the back, but I guess that in normal use, more crud gets kicked up towards the rear than the front. Unfortunately, my car sat for years and collected leaves, debris, etc in the front bumper pockets as well.
The fronts are the same on any 64 Olds full size (and only 1964). The backs are the same on any 1964 Eighty Eight model. 1964 Ninety Eight rears are different.
Old Sep 23, 2011 | 03:36 PM
royalrods's Avatar
Well the story goes I bought the car with a bad master cyl and less than 5 miles from where I bought it, my buddy decided that he wanted to drive the car ( my mistake on that ) On that note im sure you see how this story ends.
Thanks for the info guys guess Ill be looking for 64 then .
holidaysedan
Mar 8, 2011 11:22 AM
ddx77
Jun 24, 2010 10:49 PM
airlamb
Nov 29, 2009 11:46 PM
jmac69cutty's
Apr 13, 2009 07:42 AM
eke82
Ninety-Eight
Dec 14, 2006 05:40 PM
