57 olds super 88 speedometer removal/Haunted horn problem
Old Mar 25, 2013 | 07:04 PM
jgsoasis's Avatar
Hi, my name is John and I am restoring a 1957 olds super 88. I need to remove the speedometer to have rebuilt, but am having a problem getting it out per manual instructions. Anyony have any pointers on removing this item?
I also am having a problem with my horn going on and off intermittedly without pressing it. I believe the spring activator behind the horn ring is worn, and needs replacing, but cannot find any for sale, does anyone have a fix for this i
Thanks, John
Old Mar 26, 2013 | 02:09 PM
Tedd Thompson's Avatar
I may have a fix for your horn components if they are somewhat like a 55. There is a large rubber donut in your steering wheel which deteriorates and compresses which in turn causes it to lose it's insulation and ground out. There is a replacement part available through Fusick and USA Parts Supply,which will work but are thinner and less robust requiring careful attention to the tension on the steering wheel nut or it also will crush and cause the same system as you have now. You might take a look at your motor manual and see if there is something that looks similar to what I have described if different I'm giving you bogus information....Lost in the fifties ...Tedd
Old Apr 2, 2013 | 06:05 PM
amesolds's Avatar
John- Did you ever get your chrome bezel and speedo out?
Old Apr 2, 2013 | 09:53 PM
jgsoasis's Avatar
Old Apr 2, 2013 | 09:55 PM
jgsoasis's Avatar
Thanks Ted, have a ring on order, i woll let you know if it works, John
jgsoasis's Avatar
Old Apr 2, 2013 | 09:56 PM
jgsoasis's Avatar
Will be working on this wekend, and pointers? Thanks, John
Old Apr 12, 2013 | 08:35 PM
amesolds's Avatar
I have my dash bezel here if you need a pic of where all the nuts holding it in are.
Old Apr 13, 2013 | 08:22 AM
jgsoasis's Avatar
Old Apr 13, 2013 | 08:23 AM
jgsoasis's Avatar
Yes, that would be great. Did you remove it? or can I contact whoever did? Thanks, John
Old May 23, 2013 | 07:58 PM
64Laurentian's Avatar
It is possible to get the speedo out without removing the entire chrome bezel assembly. First you remove the printed circuit board off the rear of the cluster, then the fuel gauge, then the speedo. It is a bit tight working under there but it is a whole lot quicker than removing the whole bezel assembly.
Old Aug 21, 2014 | 04:56 PM
bmaneri's Avatar
57 Olds speedometer removal
John, did you ever remove your 57 Olds speedometer? I have to remove mine and am looking for any pointers. Thanks, Bob
rctoyguy
Nov 27, 2014 02:00 PM
joepenoso
Jul 12, 2013 11:03 AM
joynerz
Jul 20, 2012 10:25 AM
DennisG.
Apr 15, 2012 11:01 AM
My442
Jul 29, 2010 04:14 PM
