393tony
393tony
Hello from hegins pa. I love this site and have been reading posts for awhile now. Now I have to ask a question and post myself. Hope some one can help. I'm changing the weather strip on my 1968 442 convertable and would like to know how do I remove the vent window to do this. Thanks if anyone takes the time to help me. TONY
Vent window
I want to replace the weather strip around my vent windows on my 1968 442 cutlass CONVERTABLE. I know the post cars are differant than hardtops and convertables and was wondering if any one knows how do I take the vent window out of my convertable? Is it a hard project? Thanks in advance for any help.
Welcome, I've never changed the weather strip on a door but I have had the vent windows out of my 70 Vista which I assume are similar to your 68. You have to take off the door panel and then you can see how they come out. I can't remember if you have to take the window out to get the vent out or vise versa. You'll see after you get the panel off-It also seems like there were a few Phillips screws and a lot of 7/16 headed bolts.
The removal process is covered in the Fisher Body Manual. I suggest you get your hands on that to see where all the fasteners are located and also how to properly adjust the vent window frame after installation.
I've merged you two identical threads - you're more likely to get consistent, helpful info in a single thread. Note that convertible doors (and vent windows) are identical to those on the same year hardtop. The only difference is that convertible doors have the screwed-on wedge plates on the upper rear edge of the inner door.
The vent window for 68 for is slighty different between hardtop and vert and it's a different part number. The weatherstripping channel is different
And I can't imagine getting the vent window out without the window out but I've never tried.
Yup. Mainly due to the different windshield height and angle as compared to the hardtop, I suspect. What I should have said was that the method of removal and adjustment is the same, however.
