1976 Cutlass tire figment
Old Aug 2, 2014 | 01:49 PM
Tlo154's Avatar
1976 Cutlass tire fitment
Just purchased a sweet 1976 Cutlass Supreme. Had a76 Salon back in the day. Purchased new. I want to mount BFGoodrich Radial TA's. My salon had 4 H70-15's mounted now would be 235/70R-15. Anybody go any wider with stock SS III -5X7 rims?
Old Aug 2, 2014 | 02:09 PM
H70 was a pretty tall tire @ 28.1 inches. Your right the closest to that is the P235-70-15. You can get away with a P275-60-15 on a 7 in wheel in the back and a shorter 60 series in the front.
Here's a good calculator:
http://www.discounttire.com/dtcs/infoTireMath.do
Old Aug 2, 2014 | 02:12 PM
Tlo154's Avatar
Thanks. I guess I'm what you call old school. I'm not a fan of the larger than 15 inch tires on the older cars but just love to have the widest tires possible keeping all 4 the same size.
Old Aug 2, 2014 | 02:16 PM
You might see what 4 P255-60 or P235-60's look like on there. I think 4 P275-60's would make it look like truck.
Old Aug 2, 2014 | 02:49 PM
Tlo154's Avatar
Thanks for your advise. I will keep all of your suggestions in mind.
Old Aug 2, 2014 | 07:55 PM
oldsmobiledave's Avatar
tires
245 60 15s on all four corners will work well on your rims & look good on your car. You did not mention what rear gears you have but likely 2.73s. A tall 275 60 out back will kill off the line acceleration.
Old Aug 3, 2014 | 03:09 AM
nsnarsk65cutlass's Avatar
235/70r15 will fit with no problems,maybe a little tall as others said with most likely 2.56-1 gearing i suspect.
Old Aug 3, 2014 | 07:16 PM
texxas's Avatar
As Dave mentioned 245 60 15 is the biggest size that will fit all the way around without interference on the 15X7 wheels, provided your suspension or springs aren't worn out.
Abob89
May 21, 2025 07:45 PM
dads76olds
Sep 27, 2009 05:41 PM
1965T5
Sep 30, 2008 01:34 PM
frankenstein
Dec 3, 2007 01:29 PM
