1975 455 olds
1975 455 olds
so i just bought a 1975 455 olds got it for 300 bucks with the th400 trans i know anything after 1973 came with a lower compression. the motor was missing the distributor, carb, power steering, exhaust manifold, but who cares for 300 bucks. i checked the oil and there was no slug and the crank turned over. i don't know where to start i want to beef it up but do not have a lot of money. so i need some help guys on what to do
what are a good set of heads to go with, I want about 500 horses out of the motor when I am done. I see a lot of top end kits for performance, but I don't know if I need to change pistons for compression ratio and cam?
If you want 500 HP, start by reading the recent articles in Hot Rod magazine about what it really takes to built that much HP into an Olds motor and make it live. They spent $13,000 to get that motor to be reliable.
