1973 omega
Every thing has and will be done. There will be a lot of work to mount to get the drive shaft right etc. Very big can of worms drop in a 455 or put some coins in a good 350 Olds engine. just my 2 cents. good luck.
I don't know of anyone on our site that has posted about putting an LT1 in an Omega but that doesn't mean that someone hasn't. Not sure how well that idea would be accepted on the site either.
Your on the wrong website if that is what you want to do. If you need help with an Olds motor for your omega then this is the place. You can build up a nice SB or BB OLDS that would be wicked!
As noted, the Omega is a Nova and the LT1 is another ho-hum small block Chevy. It's your car, do what you want. Don't expect support from this forum, as we are really bored to tears with the belly-button SBC swaps.
my engine that i have now is the 350 rocket about 7 years ago i had my friend start to rebuild but right in the middle of it he told me his wife said he has to stop doing extra work for friends so NOW i have a bare block box of nuts and bolts that i have know idea how to put back together, Rebuilt head and cant remember how to put engine back in even if it was together. So thats why i was wondering about the LT1. a guy at the car show had one in his car (camaro) good on gas, and very fast he said
Buy a chassis service manual for your year. All the info you need is it there.Installing an engine is just that, installing an engine. If you can't do one, you cant do any and vise versa. The car is already set up for the Olds SB which is much easier to to than to change everything to put in the SBC. As Joe said though "It's your car, do what you want."
Face it, the easiest, cheapest way to get the car running is to either reassemble and reinstall the stock motor or to get another (running) Olds motor and drop it in. The nice thing about Olds motors is that the 455 is virtually identical to the 350 except for the deck height and is as close to a bolt in as possible. Get the Chassis Service Manual, read it, and learn while you reassemble your car. Once you've gained the skills, THEN think about an engine swap.
Yeah, the LT-1 (and LT-4) were the last of the "original" SBC motors used in passenger cars. They came with TPI and most had the dreaded Optispark system and reverse flow cooling systems.
Its always nice that when people use an RPO # that they tell you the year. It gives a lot more info. We here should know that a 67 RPOW30 and a 80 RPOW30 are not the same thing. Oops off topic. Maybe a topic for a new thread (pet peeves) then again maybe not.
If your going to use the LT1 you mays as well use the M30 or MT1 thats already behind it. Its just a bit more wiring and fabrication.
lshlsh2 you are correct on both counts but it is possible with the use of adapters.
Soooo many people don't even consider the Omega a real Oldsmobile.Don't give them any more reason to do it by putting a Chevy in it!Thanks everybody for taking up for the Omega.Suddenly I don't feel so lonely down at the bottom in the"other Oldsmobile" category.
railguy
railguy
